FULLY BUILT LS/VTEC
Old Jun 7, 2006 | 09:09 AM
boost_is_best's Avatar
Default FULLY BUILT LS/VTEC
fgds
Modified by boost_is_best at 10:38 PM 7/9/2007
Old Jun 7, 2006 | 09:37 AM
wade's Avatar
Default Re: FULLY BUILT LS/VTEC (boost_is_best)
you will max out on injector before you max the engine
Old Jun 7, 2006 | 09:50 AM
19sec beast's Avatar
Default Re: FULLY BUILT LS/VTEC (wade)
There's only one way you'll be able to tell...
Get it tuned!
Should be a fun car, though.
Old Jun 7, 2006 | 10:15 AM
97gsrki's Avatar
Default Re: FULLY BUILT LS/VTEC (19sec beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19sec beast &raquo;</TD></TR><TR><TD CLASS="quote">There's only one way you'll be able to tell...
Get it tuned!
Should be a fun car, though.</TD></TR></TABLE>
prettty much what he said. its pretty much all going to be about your fuel system maxing out, and further after that your turbo. but should have no problem getting in the 500's with a set up like that with a good tuner.
Old Jun 7, 2006 | 10:25 AM
xcvx
Old Jun 7, 2006 | 11:27 AM
purpleh22's Avatar
Default Re: (boost_is_best)
525 hp should be in reach. Depends on Exhaust (3", open or no cat., 3"dump t)
control sys. (Hondata, Neptune, Uberdata etc.) and other factors.
Check Honda-Tech tuner listing for Seattle. Ground Zero and Torquefreaks in Portland do good work. (a number of Washington residents have used them)
Old Jun 7, 2006 | 11:38 AM
i'am running 3 inch open down pipe. and yes ive heard of ground zero i might get tunned thier.
Old Jun 7, 2006 | 11:41 AM
WalkerGSR1's Avatar
whats the link to the tuner list?
Old Jun 7, 2006 | 01:50 PM
Turbo O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade &raquo;</TD></TR><TR><TD CLASS="quote">you will max out on injector before you max the engine </TD></TR></TABLE>
this is true but if you are looking to get around the 525whp mark the 1000cc you have will work out great. those injectors are good for almost 700whp. I have seen a 4 cylinder turbo setup with 550cc injectors making around 500-550whp so you should be fine. it seems like you have the right tools now just get it tuned right and you should have a beast.
Old Jun 7, 2006 | 06:58 PM
thanks for the replies, but has anyone seen a similar setup around, just woudering what they put out.
Old Jun 7, 2006 | 08:37 PM
purpleh22's Avatar
Default Re: FULLY BUILT LS/VTEC (Turbo Toyz)
Tuner list is the second topic from the top on page one of the Forced Induction listing.
Old Jun 8, 2006 | 06:43 AM
WalkerGSR1's Avatar
thanks
Old Jun 12, 2006 | 10:10 AM
bump
Old Jun 12, 2006 | 11:55 PM
quicksilver1689's Avatar
i ♥ snails
550cc injectors making 550whp? Hmmm am i missing something or maybe im just too tired.
KillAHonDa
Oct 3, 2008 05:51 PM
poland accord
11
Aug 15, 2008 01:26 AM
95lsvtech
13
Apr 15, 2007 12:47 PM
severe97
15
Mar 31, 2007 08:33 PM
viprcr1
Jun 28, 2003 05:57 PM
