Fully built GSR 545whp / 363tq @ 30psi WTF?
#26
Re: Fully built GSR 545whp / 363tq @ 30psi WTF?
actual timing spot on?
flip that turbo around and run the filter right on the housing.
is the gate open or recirc?
#28
#29
the intake pipe will make you loose power? I had just filter atached to the turbo. i figured it was sucking into much hot air so installed a pipe. This will hurt my power outcomes?
t3/t4 60 63
t3/t4 60 63
#30
#31
numbers dont seem right the intake has got to come off you might be suprised and wrap all your piping up its just some little stuff but I'd like to know what taking your intake pipe off did for you
#33
Tony,
I dont have the car with me at this time but I actually bought the turbo from you. I will try to find out. When I bought it you said it would support 750.
Yes there is a 3 inch flex pipe on the 3 inch 4 bolt peakboost downpipe
#35
The intake pipe doesn't cause a restriction when it's properly sized. If you have a 4 inch inlet on the turbo and your running a 3 inch pipe then you will have a big restriction. But if you have. 4 inch pipe then not much restriction at all.
To the op. We def need to know turbine housing size. And. If your running a flex section in the dp and it's not mesh inside like it is outside it's will cause a pretty good loss in power. I've seen as much as 50 whp difference between the two different flex sections on several cars
#36
Interesting,
I too got a downpipe from peakboost and its not mesh inside, its rivetted and ****,
you think that will hurt my performance?
#37
FYI a friend of mine and a mod on this site made 700+hp on the t3/t67ho with only 5psi or so more boost.
I dont know much about the BBK IM, but that could also be a problem.
#38
I've done setups with the 3" tube on a turbo with a 4" casting compressor housing and it's been fine. Not ideal, but not a huge loss like this setup has for whatever reason. One of our full street cars has a 35R with a 3" inlet tube like that and it runs 10.1 @ 145.
#39
I am going to inspect the flex pipe and muffler to make sure my exhaust is flowing 3 inch all the way.
I am also going to upgrade the intake to a 4" piping with the 4" velocity stack instead of the 3 inch piping with 3"stack. I will take it off at the dyno but just have that on there for the street.
the bbk IM is similar to the victorx so that is not the prob
thanks for all the input!
I am getting married and going on a honeymoon directly after so it might be a few weeks before I can get to the car or my fiance will cut my ball$ off if i change priority lol.
#40
Don't change anything. Go to a different dyno and see if there is a difference. So many factors could cause lower than expected numbers. I would double check timing then play with cam gear timing before changing any parts. A friend of mine had a b-series with a BW 372R that was making low numbers and it turned out to be the cam timing. Of course look out for obvious restrictions like exhaust. If you have a t3 H.O. housing it is the same thing as the smallest t4. My personal car made 545whp and 331tq @ 26 but I had a t67/t3 .63 backhousing and p trim stage 5 wheel. I thought that was low and wanted more but I didn't have a decent tuner. Cam gear adjustment could have got me 20-50whp
#42
I say this... intake needs to go bye bye and use a mesh screen
Take the dumb inline resonator / muffler out of the exhaust <---- i think its this big time
Use pure C16.
#44
Its not the dyno. I thought the same thing with my car so i re dyno'd in virginia beach - same numbers.
Use pure C16.
Use pure C16.
anthony your theory on this is flawed unless either the resonator or muffler is damaged (which i am going to inspect according to tony1) the 3 inch space provided is exactly that... 3 inches.
#45
ive seen it asked what 4 times now with more replies than that, and he still hasnt answered yet
turbine housing? What size exhaust?
#46
i answered tony when he asked and i do not have the car with me. I live in Suffolk Virginia, and the car is in Richmond Virginia (hometown). Talked with tony on the phone and he said ".82" to himself outloud.
#47
Using a mesh screen isnt gonna help anything. Your turbo creates a cyclone effect. If you run a screen you disrupt this entirely. If anything it will make it worse.
If your so worried about power. Cut the exhaust off right after the motor and see what it does.
You dont have to put it on the dyno to see if its making more power. Just go do a pull before you take it off. Say its 11.8 AFR. If its 12.5 its flowing more air, simple as that.
#48
Boost leak test the car. 90% of the low power issues on turbo cars that I tune are due to poor boost leak test results. You would be surprised how many leaks you'll find even on cars making good power/holding boost.
#49
GL with everything! That turbo is badass tho for sure! ;o)
