Full Race Turbo LSVTEC or GSR?
Man U FTW
Re: Full Race Turbo LSVTEC or GSR?
That's really descriptive. What are your goals and what are you planning to use this setup for?? You need to give a little more info if you want some answers...
well i just recently bought a 94 coupe and i know about what i want except the engine setup.. i've looked into a LS VTEC and into a GSR, really my power goals are around 400 hp when the boost is turned up... its a street car, i just wanted someone else's advice as to which engine would be better to use
Man U FTW
Either the LS/VTEC or the GSR will work for your goals. A simple piston/rod GSR would easily make your power goals, but if you want a little bit more displacement, you could opt for an LS bottom end or an LS crank in the GSR block. I personally opted for an LS bottom end and re-used my GSR head. Also, the oil squirters in the GSR block aren't needed with aftermarket pistons and rods. Most people opt to plug them once the bottom end is build. GE makes a nice little kit for that reason...
Man U FTW
^^beat me to it. Also, if you use the LS crank in the GSR bottom end, you have to get rid of the oil squirters or the crank will do it for you. There isn't clearance for them...
Man U FTW
Sure, cooling and oiling are good things; however, those systems were put in place due to the stock components needing both cooling and lubrication. Since aftermarket slugs dont need that, you're better off plugging the oil squirters and keeping oil pressure for other places that it could be put to better use.
LS=longer stroke=more power just my .02
yeah, so by plugging the oil squirters it re-routes the oil pressure to places, like, say..the head.. right?
nice! See the guy i bought the car from told me that he had a LS that ran for $400.00... but then i started looking into it, he said he would sell me a GSR head for 650... that along with everything else i will need..wont that be more than the price of a GSR?.. im just trying to see whats more cost effective.
rape.com
dude you can always pick up a gsr or b16 head on cl for 450 complete...
and I picked up my ls (complete engine) for $200 with absolutely everything including a ecu
sold all the stuff off it to more then pay for my ls bottom end that I used.
What is the downfall of retaining the squirters in a forged rod/piston setup? I ran both my b16a (died from oil starvation/over-revving) and now have a built GSR both retained the squirters. Perhaps I will have to consult with my builder about this.
Man U FTW
The problem with retaining the squirters is that it diverts important oil flow and pressure to an area where it is completely useless. I'm not going to say that it caused your oil starvation problem, but it could have been a factor in it. Personally, i would get rid of them when the block is open
Sounds like the plugs would of helped save your motor, oil to the main/rod bearings is needed alot more than to forged pistons..
Yes they make the plugs....
You better look around man sounds like somone is trying to rip you off those parts are expensive..
yeah, i am just waiting on the engine stuff for now as i have other areas of the car that needs to be attended to first. thanks for the advice.
