Another oil return line question...
Old Jan 22, 2009 | 01:52 AM
TehGhett0P1mp's Avatar
Default Another oil return line question...
I am just wondering if my oil return line is alright. It goes straight down and has a curve up and around the downpipe which goes into the oil pan.
The part the concerns me is that people are saying there should be no positive slope, but the incline is VERY slight and heres a pic..
Thanks!
Old Jan 22, 2009 | 05:56 AM
B and B's Avatar
Loved
Community Favorite
Default Re: Another oil return line question...
I'm gettin dizzy trying to orient the pic, but I'd put a heat sleeve around it.
Turbo noob here, don't know if that slight rise will lead to poor drain or not, need some experts opinions. Up
lighting of the pic is cool
Old Jan 22, 2009 | 06:33 AM
shortyz21's Avatar
if it smokes u know its no good.
run it and find out.
Old Jan 22, 2009 | 06:39 AM
96 GSR-T's Avatar
A very slight incline is a postitive slope, go pour some oil on a positive slope and see what happens. Best scenario is the size of the line still allows some oil to drain freely because it builds up. Go buy some AN bends/angles and do it properly
Old Jan 22, 2009 | 07:15 AM
dpetro1's Avatar
yeah i had a similar setup. a 45* on each end of the line will take care of that. in that pic it almost looks like a 45* at the pan and a slighly short line should be fine
Old Jan 22, 2009 | 07:19 AM
Flamenco-T's Avatar
You're fine...
Old Jan 22, 2009 | 08:23 AM
tegman23's Avatar
thats alot of drain line IMO, but like stated if your drive the car and its smoking its probley going to be that your drain isnt working they way it should be...just my .02
Old Jan 22, 2009 | 11:13 AM
Ill try it the way it is, if not ill just cut it a bit also does anyone know if any hardware stores would have those 45 degree fittings or would it have to be some kind of performance shop?
Old Jan 22, 2009 | 12:12 PM
m R g S r's Avatar
Just tap the opposite side of the pan, near the tranny. There should be enough room to drill and weld a fitting on there.
Kelly.
Jun 26, 2006 11:36 AM
Accurate GS-R
Oct 30, 2004 09:08 AM
dunkd
Mar 5, 2004 09:54 AM
_Endless_
Dec 8, 2003 09:48 PM
