Neukin Turbo Manifold
Alright so I'm thinking about getting the Neukin AX Manifold. It says "Neukin Open T3 or T25 Bottom mount for 200HP-500HP" Does that mean I could use my Garret T28 on it until I upgrade? I plan on using a Garret T3/TO4E 60 trim. I don't want to buy that manifold then have to buy another new one when I upgrade my turbo. If I can't use that then I guess I'll just wait but what manifold would you guys recommend? I plan on making around 300-400 hp when all said in done. It's for a 2000 Civic SI if that matters at all.
Re: Neukin Turbo Manifold (91jdmhatchback)
Thats what I thought so it will work with my t28 and when I decide to get the T3/TO4E it will work with that also, and would it be a good manifold to get if I'm looking for 300-400hp down the road?
Re: Neukin Turbo Manifold (ampere)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ampere »</TD></TR><TR><TD CLASS="quote">Thats what I thought so it will work with my t28 and when I decide to get the T3/TO4E it will work with that also, and would it be a good manifold to get if I'm looking for 300-400hp down the road?</TD></TR></TABLE>
no, you're not understanding. You can't have a t2 flange and a t3 flange on there at the same time. You either get the t2 flange, or you get the t3 flange. If you get the t2 flange, you have to then buy a t3 flange and have a fabricator remove the t2 flange from the manifold and weld the t3 flange on.
I think you've got a bit of research left to do on the whole turbo kit thing
Re: Neukin Turbo Manifold (chimmike)
ok somebody had to say it so i will lol
neukin ftw....running strong now for almost 2years
edit: just go with the t3 and upgrade by sellin that turbo and getting the one u want
Re: Neukin Turbo Manifold (orion840)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orion840 »</TD></TR><TR><TD CLASS="quote">ok somebody had to say it so i will lol
edit: just go with the t3 and upgrade by sellin that turbo and getting the one u want</TD></TR></TABLE>
Yeah thats probably what I'm going to do. So I should get the neukin would a ramhorn be overkill for only 300hp?
you know you can get a t3 housing for your t28 and when you upgrade later all you have to do is switch turbo's.
i don't know the specific housing for your trbo but they make a few t3 flanged t2 series housings
Banned
like it was just posted you can get a t31 back housing for that gt28 and save yourself the problems. for 300hp you save the money and get a log or mini ram. your get better response too. pm me if you need some help
