Fuel system question???(did a search)
Old Mar 17, 2002 | 12:39 PM
simike's Avatar
Default Fuel system question???(did a search)
I'll try to make this short. I am making my own turbo kit for a B16A2 civic si. I have RC310 injectors, walboro 255lph intank pump, stock fpr, v-afc and i am going to buy a vortech fmu. I was going to buy a 10:1 or 12:1 but not sure which? I also see that most turbo kits come with an inline pump. Do i need that with this setup? If so which one should i get? I want to run 8lbs of boost on a stock motor w/a T3/TO4E for now. Thanks for your help!!
Old Mar 17, 2002 | 12:59 PM
mannysir's Avatar
Default Re: Fuel system question???(did a search) (simike)
u need a 8:1 fmu and a fpr or u will run rich on idol like iam now.
Old Mar 17, 2002 | 01:13 PM
TurboTypeR98's Avatar
New User
I would recommend an inline pump if u are going to stay with the FMU route. There are numerous posts about inline pumps but I think most people recommend the bosch. Also the stock fpr is fine...the 310's will idle with the afc.
Old Mar 17, 2002 | 01:57 PM
SIK IN DA HED's Avatar
New User
Default Re: Fuel system question???(did a search) (TurboTypeR98)
yeah, the 310s work well in idle from what ive been told on the forum. get an inline rather than an intank. bosche works well ive heard. i got the one from the drag3 kit and it works fine as well. ive head different opinions about getting a 8:1 and a 10:1 to go with the 310s. so its up to you to decide what will work best for you. try buying both rates and taking it to the dyno to see what works best.
Old Mar 17, 2002 | 02:24 PM
simike's Avatar
Default Re: Fuel system question???(did a search) (dlplayboy)
I did another search and found ALOT OF INFORMATION on this topic. It seems that there is no sure way (intank,inline or both) mostly personal preferance. If i buy the wrong fmu can i just order a differant plate or disc from vortech? ie 8:1 or 10:1 or do i need to buy a new fmu. Thanks again. For those who have no luck with searches try "archived topics" Thats been working much better for my searches.
Old Mar 17, 2002 | 02:36 PM
New User
You can buy a recalibration kit from vortech for like $50 and it has a bunch of different disks(12:1, 10:1, etc.) I use an 8:1 disk w/ 310's. About the fuel pumps, I would play it safe and get an inline pump for an FMU setup and an intank for a standalone. I use an inline and it works fine.
Old Mar 18, 2002 | 02:11 PM
simike's Avatar
Thanks for all the help
YellowPhoenix095
May 14, 2007 06:30 AM
SIK IN DA HED
Apr 1, 2004 01:03 PM
slwazgsr
Oct 7, 2002 01:59 PM
_Endless_
Sep 2, 2002 01:28 AM
speedy108
Apr 3, 2002 01:32 PM
