Fuel System Question
Old Mar 5, 2005 | 03:59 PM
Johnny_Rocket's Avatar
Default Fuel System Question
I decided on running a FMU (12:1) with 450cc injectors on my 93 teg and I plan on running around 8 psi... Along with my Apexi SAFC... I've talked to a few people and they say this setup will be plenty for my goals which are not anything crazy. Do you see any problems I might run into?
Thanks
Old Mar 5, 2005 | 06:38 PM
beepy's Avatar
Default Re: Fuel System Question (JohnnyH)
Just a guess... I think the car might throw a CEL at 4000 RPM when you boost and then idle at about 1400 until you shut it off again.
Old Mar 5, 2005 | 09:13 PM
Default Re: Fuel System Question (beepy)
Could this CEL be because I don't have a check valve for the map sensor?
Old Mar 5, 2005 | 09:25 PM
93supercoupe's Avatar
this thing wont run right, u need one or the pther, FMU or the AFC w/440's, not both
Old Mar 5, 2005 | 09:43 PM
beepy's Avatar
Default Re: Fuel System Question (93supercoupe)
93 is basically right. You would need check valves if you were just running the FMU. The "hack" takes care of that my reducing the MAP signal to levels that won't trigger the CEL and limp mode.
You can run both... But in that case the FMU would be the primary fuel adder and the hack would just be to fine-tune. But you wouldn't want to run big injectors in that case.
Old Mar 6, 2005 | 04:40 PM
Yea, I'm sorry if I sound retarded but I'm new to turbo with Honda's. My RX7 was a lot different.
So you're saying I could keep my stock injectors, run an FMU and fine tune it if necessary with my AFC? Is it safe to use an FMU with stock injectors? I've been told its not a good idea.
Thanks guys
Old Mar 6, 2005 | 08:04 PM
Bumpity bump bump bump bump
Old Mar 6, 2005 | 08:13 PM
beepy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyH &raquo;</TD></TR><TR><TD CLASS="quote">Is it safe to use an FMU with stock injectors? I've been told its not a good idea.
Well, nobody will say it is safe.
Since you are new to Hondas check out uberdata.
Old Mar 6, 2005 | 08:19 PM
I checked out Uberdata and I'll probably get into that later on. Right now I need it to get me to work and back. I'll be puttin plates on it soon and I just don't want it to blow up. Should I go ahead and get a set of 310's or 440's...? I'll use those with my AFC for now? Or would I be better off with my FMU and 310's or 440's?
Old Mar 6, 2005 | 08:20 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe &raquo;</TD></TR><TR><TD CLASS="quote">this thing wont run right, u need one or the pther, FMU or the AFC w/440's, not both</TD></TR></TABLE>
Old Mar 7, 2005 | 02:40 PM
Default Re: Fuel System Question (PrettyLude)
So I guess for now I'll go FMU with stock injectors... Is a Vortech 12:1 FMU about right for my teg?
Old Mar 7, 2005 | 06:55 PM
bump
Old Mar 7, 2005 | 10:38 PM
PrettyLude's Avatar
10 to 1 is the right ratio for a teg
Old Mar 8, 2005 | 11:25 AM
Is a 12:1 FMU really gonna make that much of a difference?
Niskyspy
Nov 19, 2006 06:59 PM
wshondaman
Dec 24, 2004 01:45 PM
hybridb18
Apr 21, 2003 10:46 AM
SIK IN DA HED
Oct 2, 2002 08:41 PM
shadowdawn
May 15, 2002 07:32 AM
