Fuel system install help
Old Oct 1, 2013 | 11:55 AM
DelSolMike's Avatar
Default Fuel system install help
I bought a completely new fuel pump, filter, and stainless/AN line kit from GoAutoworks. I have all the necessary pieces and fittings from pump to rail to install it. I'd like to tackle this job myself instead of paying someone an arm and a leg to do it. Are there any DIY's or write ups that could point me in the right direction? This is for a del Sol... Thanks!!
***Edit***
The feed line install with everything was a breeze! Thanks for all the help!
I think I'm going to do a braided return line as well. What size should I do. The same as feed (-6) or should I do -4? What fittings do I need to connect it to the stock fuel pump carriage?
Too many lines under the car with all that. I'm pretty sure I'm going to cut out both feed and return hard lines...
I also plan on deleting the EVAP system. What is the best method to vent the stock hard line that goes to the bay? I don't want to vent it there, nor do I want it's vapors in my bay.
Old Oct 1, 2013 | 12:05 PM
Turbo-LS's Avatar
Default Re: Fuel system install help
What pump what tank
Old Oct 1, 2013 | 09:48 PM
DelSolMike's Avatar
Full blown 320 in tank. Stock del Sol Tank.
For the most part it seems pretty straightforward. Install fuel pump. Use GoAutoworks fuel line kit to go from tank to filter. It has the correct fittings I need to do it all... Now my main concern is running the stainless line under the car... What is the best method of running it, best method of attaching it to the car, do I need to worry about insulation and grounds, how to drain the system to not get fuel everywhere and how to remove the hard feed line... Any advice?
Old Oct 2, 2013 | 03:31 AM
jimbo slice's Avatar
I usually leave the stock lines alone. Run the new fuel line under the car with the new fittings and filter up to the rail. Be sure to leave a small amount of slack but not too much. You want the line to be long enough, yet not too long that it hangs down a lot. I use whatever it takes to mount the line and filter to the chassis. Sometimes it's the rubber coated clamps that use a self tapping screw.. Other times it's zip ties. What I look for most are areas where the line may chafe on and low hanging areas where it may need to be tucked up higher.
Old Oct 2, 2013 | 04:31 AM
Muckman's Avatar
Moderator in Chief
Whats the point of larger diameter feed line if you are reducing it down into the stock fuel filter? You should upgrade the filter as well.
Route the new line in the same way the stock line is. I reused the "tunnel" under the car.
I used threaded nutserts and insulated pipe clamps to attach to car. Was able to reuse the plastic fuel line tray for the front half of the lines after slight modification to accept the larger diameter hose.
Insulation and grounds? No.
I just cut the stock fuel line with bolt cutters in the middle and let it drain. No easy way to remove the line whole.
Old Oct 2, 2013 | 05:54 AM
DelSolMike's Avatar
I'm sorry, you mid understood me. Everything from pump to injectors is new. Nothing stock other than the fuel tank... My main concern about doin this task is doing the line from the tank to the filter.
Old Oct 2, 2013 | 06:19 AM
Turbo-LS's Avatar
Its super simple just route it under the car and tuck it up into the casing that holds the stock lines it should fit if its -6. If not then use cousion clamps and self taping screws and clamp it every 18-24"
Old Oct 2, 2013 | 06:58 AM
DelSolMike's Avatar
Right on! Do you recommend leaving the stock line or pulling it? What the best method of pulling it? Just really wanting to avoid a mess of fuel.
Old Oct 2, 2013 | 07:58 AM
Freemananana's Avatar
Not 100% sure on this, but my VW (engine is in the rear) had a throttle cable snap. And when I replaced that I connected the new cable to the old one and used the old one to pull the new one through the tunnel. If that makes sense, that's they way I would do it. Unless you can just feed it through the tunnel and leave the old one there, as a fall back plan.
Old Oct 2, 2013 | 09:01 AM
Turbo-LS's Avatar
I left stock lines über the car but cut out under hood
Old Oct 2, 2013 | 09:11 AM
DelSolMike's Avatar
Awesome. I think I will do it that way. Whats the best way to depressurize the system? Or am I going to deal with leaky fuel no matter what?
Old Oct 2, 2013 | 10:41 AM
Turbo-LS's Avatar
Leaks no matter what you do just have some tags handy and wel ventilated area
Old Oct 2, 2013 | 10:48 AM
DelSolMike's Avatar
Thanks!
Old Oct 2, 2013 | 01:07 PM
What I would do to limit the amount of fuel mess is run out as much fuel as possible before attempting anything. If you have a fuel hose long enough this is the best way : remove the stock return line from the regulator. Use a long piece of fuel hose and attach it to the regulators exit fitting. Stick the other end of the long fuel hose into a gas can. Start the engine. Make sure all the fuel is getting into the gas can and not all over the engine bay...and possibly cause a fire. The gas can will full up as the tank drains. This is best done with less than 1/4 tank, out doors with a fire extinguisher and with a friend helping. Hopefully someone older than 19 yrs old.
Btw I'm not liable if you burn yourself or your car or any thing else for telling you how I do things. Fuel is very dangerous and should be treated as such.
Doing it this way will remove as much of the fuel out of the lines as possible without making a mess. Yes, there will still be fuel spilling out but it isn't going to be 5gal worth.
Old Oct 2, 2013 | 04:21 PM
DelSolMike's Avatar
Yes, I plan on running as much fuel out as I can.
No, I am not 19. Far from. Still feel like it though, ha!
Old Oct 6, 2013 | 06:20 PM
DelSolMike's Avatar
Old Oct 8, 2013 | 08:47 AM
DelSolMike's Avatar
Any takers?
Old Oct 8, 2013 | 08:56 AM
Return should be at least -6. You can eliminate the EVAP al together. Just be aware that plugging the vent will allow pressure to build inside the tank. Not a good idea. I like to leave a hose connecting the vent and run it up hill on the chassis.
Old Oct 8, 2013 | 09:21 AM
DelSolMike's Avatar
Yeah, I definitely do not want to plug the vent line. I was just curious as to what the proper way of venting it would be. An open line venting gas vapors in my bay does not sound appealing.
Alrighty. What would be the best method of connecting the -6 return line back to the fuel pump housing?
danedoremus
Welding / Fabrication
21
Nov 7, 2011 11:58 AM
JLHDOHC
Apr 30, 2006 04:18 PM
1QwIkEf
Jan 28, 2006 05:05 PM
paulzy
Oct 22, 2002 03:35 PM
Hybrid
Aug 6, 2002 03:38 PM
