Fuel System Help
Old Jan 28, 2009 | 03:43 AM
b20vcrxsir's Avatar
Default Fuel System Help
Hi, I just finished building my LS Vtec Motor. My Goal is to make somewhere between 600-650 whp. I wanted to know what would be the best fuel pump(s), Injectors, and sized lines to use?
At first I was thinking of a aeromotive a1000, but i read that alot of people have trouble with them. Now i am thinking of the duel bosch 044's. What do u think?
As far as injectors i was thinking of RC 1000cc (PH), or bosch 1000cc (Sat). Is that enough?
What Size Lines??
I already have a AEM FPR and AEM Fuel Rail.
Setup.
B18A1 Block
RS Sleeved
Stock Crank
Eagle Rods
9.5:1 CR Pistons
B16Head
Port and Polished
Valve strings and ret.
GSR Cams
SS Valves
ARP Head Studs
S2 Intake Manifold
GSR TB
Peak Boost Manifold (Ram Horn T3/44)
Tial 44MM
GT35R
Old Jan 28, 2009 | 07:01 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Fuel System Help
there are a few pump options. full blown dual walbro, aeromotive eliminator, a single bosch should get you there, and if you are using a honda based ecu, use the saturated 1000's.
whats your budget?:
Old Jan 28, 2009 | 07:16 AM
tony1's Avatar
Use a bosch 044 between the factory fuel filter and the rail, a walbro 255lph in tank and the bosch 1000's. Best fuel system you can get for your setup.
Old Jan 28, 2009 | 07:23 AM
Mr. Badwrench
thats basically what we used to use on the gn's and t's.
Old Jan 28, 2009 | 07:46 AM
96 GSR-T's Avatar
Tony does the 044's location really matter? I have an Intank and Inline 255hp, I was planning on removing the Inline under the car and just replacing it with the 044, will that be adequate or should I move it up towards the rail?
Old Jan 28, 2009 | 08:01 AM
tony1's Avatar
Doesn't matter, it's just easier on a setup with a stock fuel filter to pickup at that location.
Old Jan 28, 2009 | 11:55 AM
b20vcrxsir's Avatar
Stock Fuel lines?
Old Jan 28, 2009 | 12:39 PM
Boosted_B_Series's Avatar
Originally Posted by b20vcrxsir
Stock Fuel lines?
x2
I'm wanting to support in the 600-650hp range and this looks like something I might try. Jeff Evans told me I could trap pretty high with this setup and I've been searching on the specifics.
He also said run relays and 10 gauge wire to both pumps.
Old Jan 29, 2009 | 12:43 AM
b20vcrxsir's Avatar
Ttt
Old Jan 29, 2009 | 12:46 AM
b20vcrxsir's Avatar
I also wanted to know if i put the bosch pump like u said, will the stock fuel filter handle the HP goals?
Also What relay would be the best for the fuel pumps?
Old Jan 29, 2009 | 07:42 AM
Mr. Badwrench
a regular 5 pin bosch style relay.
Old Jan 29, 2009 | 04:01 PM
b20vcrxsir's Avatar
ttt
Old Jan 30, 2009 | 10:20 PM
I think everyone is wondering...
'Stock fuel lines?' with this setup.
Old Jan 31, 2009 | 05:06 PM
LowBudgetBEe's Avatar
what size lines and how far would u go as far as hp with this setup
Old Jan 31, 2009 | 06:39 PM
tony413's Avatar
-8an feed lines
-6an return lines
single or dual bosch 044
40 or 100 micron fuel filter
10 micron fuel filter
SPDT relay
Old Feb 2, 2009 | 10:22 PM
Originally Posted by tony413
-8an feed lines
-6an return lines
SPDT relay
That's one way to do it, probably the most correct way aswell. But that way is expensive and you can support 600hp without all that work and I honestly think tony1 was talking about using the factory lines, intank pump and inline between the rail and factory fuel filter.
Old Feb 3, 2009 | 05:58 AM
tony1's Avatar
The stock fuel lines are fine with that setup.
Old Feb 3, 2009 | 01:33 PM
Sweet, thanks for your response
AdrianArteaga98
20
Apr 17, 2017 06:54 PM
Beau Gotti
Oct 11, 2006 03:41 AM
Sl0wEK
Jun 9, 2006 05:13 PM
Kamin
May 28, 2002 08:46 PM
