Fuel system?
Old Sep 15, 2009 | 05:28 PM
StolenTeg's Avatar
Default Fuel system?
Right now my fuel set up is simple as can be but i don't know if it will be enough to make 500whp like i wanted too with a few new upgrades.
Current set-up: 750cc injector, stock line, stock fpr, 255lp walbro pump. Im making 435whp on pump gas right now and everything is perfect.
I want to hit the 500whp mark and the 750cc definitely is going to have to go, i will either go with RC 1000cc or ID 1000cc but what i want to know is will my stock line/fpr be enough to get me 500whp on race gas (112 114 etc)
When does stock line usually max out with e85 also?
Old Sep 15, 2009 | 05:33 PM
Terrible One's Avatar
Default Re: Fuel system?
what's your max duty cycle?
Old Sep 15, 2009 | 06:17 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Everything stock besides 255 pump and 1000cc Injectors = E85 maxes out at about 500 whp or so... then when running pump gas/race gas typically around 600 whp or so.
Old Sep 15, 2009 | 06:34 PM
boostedcivicsir's Avatar
Mr. Badwrench
i made 540 on gasoline (not e85) with a 255, stock lines to the filter, and braided from the filter to the rail, 1200's, and an aeromotive regulator.
Old Sep 16, 2009 | 05:59 PM
StolenTeg's Avatar
Is this at stock fuel pressure 40psi with oem filter and line to the rail? if that is the case, i may as well pick e85 since a local station recently carry e85
Old Sep 16, 2009 | 06:14 PM
civic-r11's Avatar
yes it will.. but i if you want anymore.. you are going to have to add another fuel pump.. but i mean.. i am in that same bubble right now.. and i am going to add another fuel pump.. cause i don't want anything messing up on my setup.. that is my 2 cents!!
Old Sep 17, 2009 | 05:35 AM
tony1's Avatar
The ID1000's, stock lines, walbro pump and stock regulator will easily make over 550whp on gas.
bradennicely
20
May 13, 2010 04:23 PM
95accordh22a
Apr 20, 2006 04:22 PM
cjb80
Jun 15, 2004 12:21 PM
baphomet
Dec 23, 2003 10:29 PM
djdxm
Jun 20, 2003 08:52 PM
