fuel setup for 450whp on e85
Old Oct 6, 2010 | 06:59 AM
golf-mk3's Avatar
Default fuel setup for 450whp on e85
my goal is 450+ whp. 60-1 turbo. so far i have 1000cc injectors and bosch 044 pump. can i use my stock fuel lines, fuel rail, and regulator to make that kind of power on e85?
Old Oct 6, 2010 | 07:16 AM
93turbo16's Avatar
Default Re: fuel setup for 450whp on e85
What 1000cc injectors do you have?
If you have the ID 1000cc injectors then you should be ok, as long as you run a higher base pressure with an intank walbro and the bosch 044.
So the stock regulator might be your limiting factor as you will definitely have to turn the fuel pressure up.
Old Oct 6, 2010 | 09:09 AM
golf-mk3's Avatar
prescision injectors. and your recomending running 2 pumps. in take 255 and in line bosch? any recomendations on whats a good FPR with stock rail?
Old Oct 7, 2010 | 05:27 AM
golf-mk3's Avatar
anymore input
jp1racer
Dec 8, 2009 09:57 PM
01PYTypeR#1140
Apr 8, 2007 03:14 PM
endlessdv
Jan 9, 2006 12:47 PM
Malice
Jun 7, 2002 11:31 AM
Tripz
May 6, 2002 06:04 PM
