Fuel Rail question here.....
Old Jun 16, 2004 | 06:11 PM
80884's Avatar
Default Fuel Rail question here.....
When is an aftermarket rail needed? also an aftermarket FPR?
This question sounds stupid but i was told that all i needed was a stock rail and reg for what i want. Didn't sound right to me...what are the limits of the stock rail and regulator?
can it support 500+whp? Thats what this guy is telling me.
Old Jun 16, 2004 | 07:18 PM
dunkd's Avatar
good question
Old Jun 16, 2004 | 07:23 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Fuel Rail question here..... (80884)
rail yes. regulator, hell no. at that point you will need a good aftermarket fpr. but there you will probably be using AN lines and need an aftermarket rail for use with them anyway.
Old Jun 17, 2004 | 07:37 PM
80884's Avatar
Default Re: Fuel Rail question here..... (boostedcivicsir)
So the stock rail will work, but i need to use a fpr that won't requre me to run an lines?
I need to buy this stuff either way, i just need to know what to get and don't see spending $300+ on something i won't need.
What do you recomend?
Old Jun 18, 2004 | 07:34 AM
earl's Avatar
I agreee on the aftermarket regulator. If you have an aftermarket hi performance fuel pump, you need to be able to control it's output properly.
Old Jun 18, 2004 | 09:40 AM
Boostfed's Avatar
New User
Default Re: Fuel Rail question here..... (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">I agreee on the aftermarket regulator. If you have an aftermarket hi performance fuel pump, you need to be able to control it's output properly.</TD></TR></TABLE>
I totally agree! The stock fuel rail can support high horsepower, I was on one at 500whp. The regulator needs to adjustable to either lower or increase your fuel pressure when needed in tuning, also have a diaphragm that won't burst and be 1:1.
edit:Also as Earl said you need the regulator in order to control fuel pressures form an Aftermarket fuel pump. You may be sitting at 40psi with say a stock pump but then add an Aeromotive or othe rhigh flowing pump and then will be 50psi or higher. You need a good regulator to increase or decrease your fuel pressure.
Old Jun 18, 2004 | 08:56 PM
80884's Avatar
Default Re: Fuel Rail question here..... (Boostfed)
Thanks a lot for the info. I guess my only thing left to do is to find a good regulator. Hell maybe i'll just buy the rail now too that way i won't have to worry about it.
Either way, thanks
Old Jun 18, 2004 | 11:11 PM
NJcoupe's Avatar
go with an aeromotive
lowtegsr
Feb 5, 2008 01:02 PM
ballerchild
10
Mar 17, 2007 11:16 PM
racekar711
Nov 22, 2005 12:13 PM
420aNT
Mar 10, 2003 10:40 PM
