turbo B18B1's. Best way to install catch can properly, and which can?
Just wondering exactly how to set this up, and if someone could explain what it does the way you think it should be set up, that would be great. thanks.
Re: turbo B18B1's. Best way to install catch can properly, and which can? (pushinlsteg)
Hi Corey A catch can system helps catch excess blow by from your crank case breather system. WHen you prssurize a honda (boost) it completely shuts down the PCV system (PCV only goes one way) when u install a catch can, it will catch all the excess oil and also help raise ur octane rating some bit (oil going back to I-M isnt good)
Re: turbo B18B1's. Best way to install catch can properly, and which can? (VNTEC)
hi thong. Thanks for the info...just because you want to sell me your can you think you can get on here and run this ****. You won't take the time to explain everything to me biotch. haha.
DC_andrew
08-14-2004 02:48 PM
Greyout
04-14-2003 07:46 AM
