fuel rail modification
Old Feb 18, 2006 | 10:50 PM
redboost10's Avatar
Default fuel rail modification
i have a aem fuel rail at the moment, i plan to run precision 1000cc injectors. i have heard that the aem fuel rail injector ports need to be modified to accept the precision injector head. is this true? also, does the golden eagle fuel rail need this modification?
what fuel rail are the 500whp+ guys using? thank you for any information guys. good luck this season.
Old Feb 19, 2006 | 12:27 AM
redboost10's Avatar
Default Re: fuel rail modification (tgh99si)
will the aem do just fine? just drill out the injector ports a little. the aem has a 1/2" bore and the ge has a 11/16" bore, any comments?
Old Feb 19, 2006 | 08:24 AM
redboost10's Avatar
to the top
Old Feb 19, 2006 | 01:11 PM
redboost10's Avatar
anyone using the golden eagle fuel rail with precision injectors? did the injectors fit without drilling the ports bigger?
Old Feb 19, 2006 | 01:37 PM
N20civicB18's Avatar
the bore is of the fuel passage through the rail not the holes. I run precision injectors with aem rail, no problems
Old Feb 19, 2006 | 01:42 PM
redboost10's Avatar
Default Re: fuel rail modification (N20civicB18)
awesome, thats all i wanted to know. thank you for the information
Old Feb 19, 2006 | 04:15 PM
troyk kms's Avatar
Got a rail from ross machine and put the holes in it myself and the tabs on it and the fittings on the ends i needed.
Old Feb 19, 2006 | 04:17 PM
redboost10's Avatar
Default Re: (troyk kms)
custom fuel rail sounds nice.
anyone running the bdl rail on a 500+ whp civic? what size is the thread on the endports?
Old Feb 19, 2006 | 05:50 PM
troyk kms's Avatar
For mine I used -8AN fittings. I will use -6AN for another rail.
KdF
Jul 27, 2009 02:12 AM
Mr si99
15
May 16, 2005 06:13 PM
stinger
Apr 24, 2005 04:09 PM
bluebullet
Jan 7, 2004 08:44 AM
