fuel rail do/donts???
Old Dec 30, 2008 | 01:20 PM
1fastacvw's Avatar
Default fuel rail do/donts???
new to efi
im building a custom intake manifold and am looking for information on how to drill the fuel rail out properly. also some ideas for mounting the rail too, what should i do/dont regarding that too.
could you please provide some do/donts on how to do this/
also, im looking for steel injector bungs.
ty
dean
Old Dec 30, 2008 | 02:02 PM
tech7427's Avatar
Default Re: fuel rail do/donts???
drill the rail out for what? im a bit confused.
Old Dec 30, 2008 | 03:59 PM
1fastacvw's Avatar
for injector to fit in?
im new to efi so maybe i mis-stated something.
im assuming that fuel rails are extruded rail with only the ends open to be tapped for fittings. what do you do to the fuel rail where the injector is supposed to go? i see there are special drill bits available but are they really needed. can a standard drill bit be used or does the fuel rail need or should be put on a end mill to be opened up where the injector will go or sit.
this is for a custom injector placement, not oem.
hopefullly i explained my enquiry better.
ty
dean
Old Dec 30, 2008 | 05:23 PM
tech7427's Avatar
i dont see why a common drill bit wont suffice. just clean up the hole for any burrs and such. for the ends you can just use a npt tap and then get npt - an fittings.
Old Dec 31, 2008 | 06:50 PM
1fastacvw's Avatar
heres what i was hoping to achieve from this post.
ref. 'how to drill fuel rail' about half way down.
http://extrudabody.com/TechInfo/Rail_Drilling.html
a267mm
Welding / Fabrication
Jun 12, 2012 03:20 AM
bluebullet
Jan 7, 2004 08:44 AM
jabroni95gsr
Apr 15, 2003 05:05 AM
