fuel questions
Old May 27, 2009 | 11:33 PM
4drlsvt's Avatar
Default fuel questions
looking for 600whp on pump i know its possible but what fuel upgrades are neccassary i have so far intank 255 and bosch 1000cc do i need inline as well?? also are stock fuel lines fine
Old May 27, 2009 | 11:57 PM
GT35R_EF's Avatar
Make mine whatever you want
Default Re: fuel questions
Mannn search! But just because I'm bored...I'll help. You definitely either need to run a bigger pump, or add another one. You could do a dual walbro in-tank setup, or run a inline pump (bosch 044) with a larger feed line, then use your stock feed line as a return.
That is what you will hear all day here.
Old May 28, 2009 | 04:58 AM
redlinetuning's Avatar
^ditto.
Old May 28, 2009 | 06:01 AM
turbo-crx's Avatar
you can probably get away with the single walbro with the pressure bypass modification and turn up the base fuel pressure.
schpiel
Jul 10, 2008 01:08 PM
JLHDOHC
Feb 10, 2007 08:16 PM
rice a roni
Feb 23, 2006 09:08 AM
JLHDOHC
Oct 18, 2005 12:54 PM
