Fuel Pumps and Injectors vs VAFC
Ok this might be a pretty stupid question but reading these forums i see a lot of ppl talk about good fuel pump and higher cc injectors. Logically from perspective an aftermarket pump along wth bigger injectors basically equal more fuel into the engine right? So why can't the same effect be created using a VAFC system?
Re: Fuel Pumps and Injectors vs VAFC (EF8_SiR)
a VAFC just maximizes the output of the injectors and fuel pump at certain rpm levels, they do have a limit, a high volume fuel pump and injectors, if tuned right, greatly reduces the likelihood of running a lean mixture. and we all know what that can do.
the reason people use bigger injectors and pump is the wear and tear items see by trying to overpreform them its like trying to get gallons water thru a straw versus a pipe which one will fail first the straw. for a 75 shot just get a wet kit and colder plug / retard the timing
Evans-Tuning.com
10-04-2010 07:08 PM
Evans-Tuning.com
Performance
12
06-01-2009 05:04 PM
deucedeuceEK
06-02-2007 04:33 AM
b16nonoy
15
07-10-2006 12:29 AM
