Piston size for JRSC on GSR?
Old 10-31-2002, 09:09 AM
metal-x's Avatar
Default Piston size for JRSC on GSR?
what is a good piston size for JRSC setup I want to go 10psi on charger
also should I resleve or not?
thank...
Old 11-04-2002, 12:00 PM
TGUNNER's Avatar
Default Re: Piston size for JRSC on GSR? (metal-x)
Im wondering the same... anyone??
Old 11-04-2002, 12:31 PM
Holden's Avatar
10psi is working well on my stock pistons!
Old 11-05-2002, 05:45 AM
metal-x's Avatar
Default Re: Piston size for JRSC on GSR? (Holden)
10 psi with stock internals?
Old 11-05-2002, 07:00 AM
Corr Performance Pilot
Muad'Dib's Avatar
yeap. no problems here either.
Old 11-05-2002, 08:59 AM
i2un's Avatar
Well, it's sounds more like your being forced to rebuild. Cracked a ring/ringland or something?
If so, your piston size is going to depend on the condition of your stock sleeves. I'd probably look for something at (81.5) .20 over and bore and hone the sleeves.
If you have the cash to buy iron ductile sleeves then I'd probably change the quench area and get something around 83mm. This may not be the optimal size for the JRSC because it may lower your boost a bit and the charger doesn't have much to spare. But I can't see myself with a built block and keeping the Charger for long. 250whp on a built block....yuck. It would be a nice size in preparation for turbo though....in case the charger dies.
Also, don't forget to keep the pistons compression ratio up near stock levels. Lower compression may help with detonation but it kills boost. Let's say you bought a CRV pulley for 10lbs of boost but your compressions now lower, and your quench area is bigger and that 10lbs pulley only nets you 7lbs.....that would be enough to **** me off.
Either way, good luck.
HPfreak
12
11-28-2011 05:19 PM
8083tcman
10-20-2008 05:03 AM
swappedcx
08-13-2007 07:29 PM
hypa
01-26-2004 08:53 AM
rOby
07-15-2002 10:16 PM
Quick Reply: Piston size for JRSC on GSR?
