fuel pump question?
Old Jan 24, 2002 | 11:42 PM
austrian type-R's Avatar
Default fuel pump question?
I have the JR-fuel pump installed now, cause it was included in the JRSC kit. I´m getting the DRAG III kit soon and there is also a fuel pump included. Should I replace the JR pump with the DRAG one. Or is it okay to use the JR brand?
Thanks
Old Jan 24, 2002 | 11:47 PM
5gen-hybrid's Avatar
New User
Default Re: fuel pump question? (austrian ITR)
You should be fine using the JR pump.Brand will have nothing to do with it.Is the pump an in-line or in-tank pump?I'm not a big fan of the in-line fuel pump.The whole push/pull scenerio doesn't sit to well with me but hey thats only my oppinion.If you have a chance to go with the in-tank (the propper way imo) i'h recomend that.I beieve the jr pump is a high volume and high pressure pump if not you will need a high volume and pressure pump to supply ample fuel under boost.
Old Jan 25, 2002 | 12:14 AM
Default Re: fuel pump question? (5gen-hybrid)
It was the stock replacement for the intank pump. Yes, it is an intynk pump
Old Jan 25, 2002 | 12:38 AM
Arturbo's Avatar
Better than steak
25 Year Member
You should be fine with the intank pump since you are going stand alone. If you had gone the FMU route I'd recomend stock pump, or walbro, with an inline pump.
art
gSr_jB
Feb 28, 2003 06:21 PM
1 2 NV
Sep 4, 2002 12:44 PM
recall
May 5, 2002 04:11 PM
D-SPEED
Nov 27, 2001 05:22 PM
GSR_Dude
Oct 25, 2001 11:28 PM
