Fuel Pump suggestions....
Old Aug 28, 2002 | 07:05 AM
20lb.teg's Avatar
Default Fuel Pump suggestions....
Alright, I've seen a couple of posts on here by searching but none of them are quite what I need. Ok, here's the deal. I have an Acura integra LS with 8.5:1 forged pistons and a fully built block, it's turbocharged and I have (for right now) 550cc Lucas/RC low impedience injectors now i will beb oosting 15 psi on the track and about 21 to eventually 25 lbs of boost at the track. I have a hondata to tune all my fuel maps, and I plan to realistically make about 400 to the wheels at 21-25 lbs of boost. Now my main question is to run on the 550 cc injectors what fuel pressures am I going to have to run with the 15lbs on the streeton 93/92 octane, and what fuel pressures for the 25psi at the track on 110 octane. And after that is determined, what kind of fuel pump would you recomend. I have an offer that I can get a 2000 prelude Type-SH fuel pump for free until I need something larger. There was an article in Honda TUning or something of the like with prelude stock fuel pump specs and it was pretty damn respectable!!! So i know it will last me the 15 psi of fuel pressure as long as I have a normal fuel pressure, but what pressures should I expect to run at and what pump would be best. Thanks for the help in advance guys (and girls).
Later,
Sean C.
Old Aug 28, 2002 | 08:12 AM
B20T's Avatar
Default Re: Fuel Pump suggestions.... (20lb.teg)
Just get a drop in 255 for what hp you want it will handle up to 500hp anymore then that you would need the inline huge pumps.
Old Aug 31, 2002 | 04:50 AM
20lb.teg's Avatar
Default Re: Fuel Pump suggestions.... (B20T)
thanks for the succestion anyone else.... I was kind of looking for what brands are also good. Walbro, Aeromotive, etc...
Old Aug 31, 2002 | 05:34 AM
Arturbo's Avatar
Better than steak
25 Year Member
What he meant by a 255 is a walbro. Dont forget you need a resistor box with those injectors.
As for the other questions Im gonna let the hondata tuners answer that question.
art
Old Sep 2, 2002 | 08:13 AM
20lb.teg's Avatar
Default Re: Fuel Pump suggestions.... (Arturbo)
to the top...
Old Sep 9, 2002 | 07:12 PM
20lb.teg's Avatar
Anybody using the MSD pump, or the Bosch pump from ENDYN. I think I'm going to get the Bosch from ENDYN and just wondering if anybody runs it. Thanks.
Later,
Sean C.
VTECth1s
Apr 22, 2006 09:42 AM
Todapwr
May 12, 2004 07:51 PM
riot
Feb 10, 2002 11:18 AM
smoothludey2
Oct 1, 2001 03:27 PM
