Fuel pump Options....
Old Jan 16, 2003 | 08:28 PM
*Boostwerks*'s Avatar
Default Fuel pump Options....
Well I have came to the conclusion that I am going to run a 12 gallon Summit racing fuel cell instead of mod my stock tank. I figured this would be more reliable, and easier to setup in the long run.
The outlet on the tank is 8AN.
What fuel pumps are out there that will allow the use of AN lines and fittings, OTHER then the Aeremotive?
I am basically looking for a pump that is less expensive then the aeremotive yet still allows the usage of AN fittings.
Thanks
Bryson
Old Jan 16, 2003 | 08:37 PM
Flamenco-T's Avatar
Default Re: Fuel pump Options.... (Bryson)
aeromotive is prolly the ones that's gonna be in a budget range..as far as inline external pump..
you may also look at paxton, bosch and etc..most will have -8 in and out fittings
the way I look at it is, if you have gone as far as external fuel cell, and bigger lines, you're serious about power and reliability, might as well get the aeromotive...
stan
Old Jan 16, 2003 | 08:49 PM
Default Re: Fuel pump Options.... (Flamenco-T)
Thats what I thought I would hear.
I was just looking to see if there were any other recomendations anyone had that might be cheeper.
Old Jan 17, 2003 | 11:08 AM
Bump....
any other opinons?
Old Jan 17, 2003 | 11:11 AM
reXem's Avatar
Why are you running a fuel cell?
Old Jan 17, 2003 | 11:19 AM
Default Re: Fuel pump Options.... (reXem)
- Easier to setup then mod the stock tank.
- I will be able to use all AN lines and AN fittings meaning it will be very reliable and hassle free (theoreticly).
- The fuel cell it self is a lot lighter then the stock tank
- Will be safer for racing.
- And of course look nicer in the end.
Old Jan 17, 2003 | 11:39 AM
ArizonaTurbo's Avatar
SX makes an external fuel pump as well.
Old Jan 17, 2003 | 12:00 PM
Default Re: Fuel pump Options.... (TurbochargedSER)
How does that compare to the Aeremotive? Any info or links would be great!
Thanks
Old Jan 17, 2003 | 01:57 PM
D-Man's Avatar
Im running a 370lph Bosch Pump #0-580-254-044,it had 18mm threads on the inlet and 12mm threads on the outlet,i got the pump with AN fittings on it from tom at payntech,i forgot the exact $ i paid for it..i think it was around $250 ..hope this helps.
Old Jan 18, 2003 | 03:26 AM
reXem's Avatar
Default Re: Fuel pump Options.... (D-Man)
Still not answering my question...why would you need to modify a stock tank? Just to change the pump? Cuz that takes no time at all, and even if the fuel cell is lighter you still have the stock tank adding the weight....
Old Jan 19, 2003 | 10:38 PM
Because the stock tank would not accept An lines and an external pump. I'm sure I could come up with some way to use the stock tank with AN lines and an external pump, but in my eyes it's too much of a hassle.
I will remove the stock tank once the fuel cell is installed.
Old Jan 20, 2003 | 05:12 PM
reXem's Avatar
Ah ok...so I take it you wont be taking this car on any more trips?
Old Jan 20, 2003 | 05:34 PM
No. This car is basically a race/occasional weekend car.
I am leaning more towards the racing. When I say racing, I mean all kinds....Solo, Drag, ATA....ect....
viet_boi_racin
Feb 3, 2008 09:34 AM
boosted96teg
Jan 31, 2007 09:07 PM
cjb80
Jun 15, 2004 12:21 PM
Tyson
14
Mar 29, 2004 12:05 AM
