Fuel pump off then on??
Old Jun 7, 2008 | 10:11 AM
tegman23's Avatar
Default Fuel pump off then on??
Hello all and thanks for the help in advance...
Ive had this problem before in a simalar way but not like last night. I took my built b16 boosted to the track when i would turn the key the fuel pump would prime but when i would try to start the car it would drop to 0psi....i would pull the main relay unhook the battery and it would fire up..Letting it sit there and idle in the stage lanes it was fine but when you would try to turn it off and start it no pump???
Has anyone had this problem before ive check my grounds...and today the car started up fine with no issues? is it carma? or should i be looking for somthing? Thanks
Old Jun 7, 2008 | 10:58 AM
dc5tegk20's Avatar
Default Re: Fuel pump off then on?? (tegman23)
This can be a few things.
My guess is either a bad relay or the main capacitor in your ecu is going bad. It is not allowing the ecu to prime the pump.
When this happens does the car throw a constant check engine light?
Old Jun 7, 2008 | 11:25 AM
tegman23's Avatar
i brought an extra main relay and switched them back and forth did the same thing...
and for codes it was not throwing any codes the whole night hondata was running perfect
Old Jun 7, 2008 | 12:42 PM
94delslo's Avatar
Default Re: (tegman23)
I'm having the same problem. i thought the problem was my killswitch was not working properly. checked it and that wasn't the problem. in my case, i found that wiggling my fuel pump wire would cut the power to the pump or give it power. I'm pretty sure i have a short some where but i haven't had any time to do re wire it
Old Jun 8, 2008 | 06:47 PM
tegman23's Avatar
anyone else? i drove the car yesterday not one problem..now today it did it one time out of no where????
Old Jun 9, 2008 | 07:05 AM
mike93eh2's Avatar
my car does this exact same thing every now and then. i have not found what causes it.
Old Jun 9, 2008 | 07:45 PM
tegman23's Avatar
ouch...if somone figures it out let me know..its very anoying..i let my car idol in the stage lanes at the track in fear the pump may not kick on when im up
Old Jun 11, 2008 | 12:26 PM
tegman23's Avatar
anyone?
Old Jun 11, 2008 | 02:14 PM
a1320addict's Avatar
How old is the car? Sounds like a short or bad connection.
You're probably best off rewiring right off the alternator with a relay and a switch.
Old Jun 11, 2008 | 04:26 PM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegman23 &raquo;</TD></TR><TR><TD CLASS="quote">ouch...if somone figures it out let me know..its very anoying..i let my car idol in the stage lanes at the track in fear the pump may not kick on when im up</TD></TR></TABLE>
i had to do the same thing last time i was at the track. have to wait a couple minutes and then the pump would start working again to be able to start it back up. its only done this like twice a year...but still very odd. main relay soldering is good and so is all wiring. the pump is only a couple thousand miles old.
Old Jun 11, 2008 | 07:02 PM
tegman23's Avatar
Default Re: (a1320addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">How old is the car? Sounds like a short or bad connection.
You're probably best off rewiring right off the alternator with a relay and a switch.</TD></TR></TABLE>
Its a 1992 Da obd1 nothing is hacked all pluged in...I was going to wire it to a new relay but, if its doing that somthing is wrong, and i would rather work the bugs out..im going to try to find a short somewhere..
Old Jun 15, 2008 | 07:31 PM
tegman23's Avatar
please help someone the car did this 3 times today.. Do you think i should just wire it off the alternator to a new relay?
Old Jun 15, 2008 | 07:58 PM
94delslo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegman23 &raquo;</TD></TR><TR><TD CLASS="quote">please help someone the car did this 3 times today.. Do you think i should just wire it off the alternator to a new relay? </TD></TR></TABLE>
do you have a kill switch? the reason i ask is because my female connectors to the switch had burnt up causing a bad connection. i have been experinceing the same thing as you have for a few months now. so all i did was re wired the connections to the switch yesterday and problem solved.
Old Jun 15, 2008 | 08:15 PM
mike93eh2's Avatar
mine did it again yesterday.. impretty sure its the solder connections inside the main relay. VERY VERY common problem on older hondas. my old accord did the same thing until i resoldered the main relay. im gonna pull mine off tommorow and check it.
Old Jun 15, 2008 | 10:16 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (mike93eh2)
main relays are known for doing this, the solder cracks and expands when heated during the summer and is known for causing problems
Old Jun 16, 2008 | 01:09 PM
tegman23's Avatar
Default Re: (EARLdaSQUIRREL)
I do have a kill switch but i disconnected it thinking it could of been that...but the car does it every once in a while.. some days drive all day nothing some times it wont turn on...i hate this should i just rewire a new relay??
Old Jun 16, 2008 | 01:17 PM
try finding a known good main relay and see if that fixes your problem
Old Jun 16, 2008 | 02:48 PM
mike93eh2's Avatar
well i opened up my main relay. all the solder in it look perfect. no cracks or seperating.
Old Jun 17, 2008 | 10:52 AM
tegman23's Avatar
same mine does not look cracked or anything...maybe buy one from honda? are they at a decent price or just expensive?
Old Jun 17, 2008 | 12:17 PM
mike93eh2's Avatar
my main relay is fine, no point in buying a new one.
Old Jun 18, 2008 | 07:30 PM
tegman23's Avatar
i wish i could figure this prolbem out...the car starts right up then somtimes i have to sit there for a minute..
greyEG
May 30, 2013 07:01 PM
Hiboost 2.0
Apr 29, 2013 12:09 PM
01 LudeDude
Sep 29, 2011 06:08 PM
madmax94
Feb 28, 2011 02:03 AM
ThatRHDstatus
Aug 8, 2010 08:05 AM
