Fuel Pump?
Old Jan 12, 2003 | 11:51 AM
89SiR's Avatar
Default Fuel Pump?
I was told that a Supra TT fuel pump is a strait bolt in into an EF. Has anyone tried this?
Old Jan 12, 2003 | 11:58 AM
BoostedED9's Avatar
Default Re: Fuel Pump? (89SiR)
i am runing a supra tt pump in my crx, it fit like stock i even changed the sock on it and put hte crx one on, i just ran new power lines to a relay with a constant 12v power going to it.. fits like stock, looks like stock
Old Jan 12, 2003 | 12:16 PM
89SiR's Avatar
Default Re: Fuel Pump? (BoostedED9)
Excellent! Thanks for the info!
Old Jan 12, 2003 | 12:59 PM
Slick GS-R's Avatar
what do they put out for pressure?
Old Jan 12, 2003 | 01:04 PM
89SiR's Avatar
Default Re: Fuel Pump? (Slick_GS-R)
255 I've been told.
Old Jan 12, 2003 | 01:06 PM
Slick GS-R's Avatar
how much can you pick those up for (used I would assume)?
Old Jan 12, 2003 | 01:12 PM
89SiR's Avatar
Not sure yet but I was told its should be alot cheaper than the other name brands like Holley.
Old Jan 12, 2003 | 06:19 PM
turbo Si's Avatar
I run a tt supra pump in my 99 Si, and it fits fine. You will have to use a flexable sock, not the hard sock. I've seen on a Supra sit in the past that at, 12 volts it's 265lph.
Old Jan 13, 2003 | 05:12 PM
khang77642's Avatar
Default Re: Fuel Pump? (suprfast)
that's a pretty good price
Old Jan 13, 2003 | 05:18 PM
89SiR's Avatar
Thanks suprfast! I'll let u know.
sasinorm01
Nov 6, 2014 09:05 PM
ElswickB22
Mar 6, 2014 08:04 PM
JRex89
Mar 16, 2004 02:08 PM
gtcali
Jan 31, 2003 10:01 PM
dlric
Nov 11, 2001 06:50 PM
