fuel pump, 190lph or 255lph??
I'm going to be running ~5psi of boost from a jrsc on a 92 civic. Would a 190lph pump be enough fuel? or would a 255 be better?
running stock injectors, stock fuel rail, with b&M fpr and either 5:1 or 10:1 FMU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockgreencivic »</TD></TR><TR><TD CLASS="quote">I'm going to be running ~5psi of boost from a jrsc on a 92 civic. Would a 190lph pump be enough fuel? or would a 255 be better?
running stock injectors, stock fuel rail, with b&M fpr and either 5:1 or 10:1 FMU</TD></TR></TABLE>
Since you're using an FMU, make sure you get the high pressure pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com »</TD></TR><TR><TD CLASS="quote">
Since you're using an FMU, make sure you get the high pressure pump.</TD></TR></TABLE>
Ahhh good point. Hey Ben, don't you sell these (blatent attempt to get fellow HT member to buy from Ben)
LOL yea we do, thanks. There are plenty of vendors that sell these pumps. Spread the love around...just not too much.
stock injectors will require a 12:1 fmu. And I would go with a high out put INLINE pump. the intanke wont produce enough pressure for the FMU to funtion correctly.
Rob
Rob
lowboost civ
Oct 1, 2003 05:10 PM
