fuel problems!!!!
here it is as brief as possible. my boosted hybrid crx has been running CRAZY rich since my turbo install. ive tried leaning it out with my vafc, tried running without my inline pump,replaced my fuel pressure reg,installed an msd,and even upped the boost just for the heck of it.i heard that normally when injectors go bad you run lean but haven't tested them yet.would it maybe be the FMU...? any suggestions will be appreciated cause im just plain sick of this 14 mile per gallon crap!
almost forgot, my idle is rough with bad hesitation when you try to rev . its almost like it floods and the same thing happens occasionally when just driving at a steady rpm. it kind of loads up or bogs / hesitates .thats the best description of yhe problem i can give...
how can i test whether or not the FMU is stuck.... should i just take it off temporarily and drive on really low boost to see if it runs leaner ?
