... fuel pressure regulator with vafc hack
Old Sep 17, 2002 | 06:59 AM
1.8T_EG's Avatar
Default ... fuel pressure regulator with vafc hack
... what fuel pressure regulator do you recommend using?... from what i have searched, i know you do NOT use a boost dependant one like the vortech fmu... should i just go with the stock one?... or will the aem one work?... lemme know... thanks...
Old Sep 17, 2002 | 07:08 AM
CzanSOHC's Avatar
Default Re: ... fuel pressure regulator with vafc hack (1.8T_EG)
the stock one should be good, AEM is nice, if you have the money get it, but you don't really need it. Whatever you do don't get the B&M one.
Old Sep 17, 2002 | 07:09 AM
1.8T_EG's Avatar
Default Re: ... fuel pressure regulator with vafc hack (CzanSOHC)
... what's wrong with the B&M one?... i 'think' i read that is was good also because it was adjustable to 1:1... am i mistaken... lemme know... thanks...
Old Sep 17, 2002 | 07:19 AM
CzanSOHC's Avatar
w/ the B&M command flow, think thats what it's called, you can only turn UP the fuel pressure, you can't turn it DOWN. AEM is adjustable from 35-65 psi i think.
Old Sep 17, 2002 | 07:29 AM
genop's Avatar
I can tell you from experience, I have had nothing but problems running the afc hack with the B&M command flo, for some reason my fuel pressure will just decide to change, maybe something I am doing.....but I am replacing it with the stock unit just to be sure.
Paulie Pesos
May 7, 2007 01:01 PM
97F22B2
Dec 28, 2003 02:00 PM
J.R.
Mar 18, 2003 04:38 PM
zojirushi
Aug 16, 2002 03:24 AM
snake01
May 31, 2002 12:54 PM
