Fuel Pressure Drops? What could it be?
After upgrading my fuel system, I've been noticing a problem with the fuel pressure dropping after driving the car.
Fuel Setup:
- Aeromotive 1000 Fuel Pump
- -10an Steel Braided Feed Line
- -6an Return Line
- x2 inline filters (1 before the pump) (1 before the fuel rail)
- Aem Fuel Rail
- Aeromotive Bypass FPR
I made sure the bolt on top of the FPR is not moving, but the fuel pressure seems to be dropping anywhere from 10 to 20psi, depending how long I drive the car before checking it and raising it again on the FPR.
Anyone have an idea what the problem could be?
Thank.
Fuel Setup:
- -6an Return Line
- Aem Fuel Rail
Thank.
it can either be the pump or the FPR. if it keeps dropping after u drive it then its the FPR. did u sump ur tank? change the fpr and check to see if it solves the problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 »</TD></TR><TR><TD CLASS="quote">it can either be the pump or the FPR. if it keeps dropping after u drive it then its the FPR. did u sump ur tank? change the fpr and check to see if it solves the problem</TD></TR></TABLE>
Vacuum lines have been checked and there is no leaks. Yeah the tank has been sumped.
Louie_EM1
May 15, 2004 01:12 PM
