Fuel Filters
Fuel Filters
Is it necessary to have a high flow fuel filter (ie. aem or other aftermarket) to supply sufficient fuel to your fi setup. Say up to like 350 - 400 hp. Or is a stock honda fuel filter system good enough. Thanks for any help you guys give.
Re: Fuel Filters (rdeezy78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdeezy78 »</TD></TR><TR><TD CLASS="quote">Is it necessary to have a high flow fuel filter (ie. aem or other aftermarket) to supply sufficient fuel to your fi setup. Say up to like 350 - 400 hp. Or is a stock honda fuel filter system good enough. Thanks for any help you guys give. </TD></TR></TABLE>
OEM worked for me just fine at 372 (as far as I know). Now the AEM one is working just fine. BTW: Nice avatar
Re: (lucidvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucidvtec »</TD></TR><TR><TD CLASS="quote"> and u can get it in different colors maybe to match ur setup</TD></TR></TABLE>
^^^thats a must
^^^thats a must
Re: (lucidvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucidvtec »</TD></TR><TR><TD CLASS="quote">i like the AEM...oem will work fine....
with the AEM u can buy replacement filters and u can get it in different colors maybe to match ur setup</TD></TR></TABLE>
how many miles should u got on the AEM filters I think im due for a change been like 12k maby
Re: Fuel Filters (N20civicB18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 »</TD></TR><TR><TD CLASS="quote">I run OEM, change it every 10k</TD></TR></TABLE>
If you change your filter that often, it might be worth it to upgrade to an AEM or other aftermarket filter. OEM ones seem to typically cost $20-25, which is pretty steep for just a stupid filter, but part of this is because you're throwing away a perfectly good metal housing every time. With the AEM and others, you only replace the filter element, which costs only $5-10. I think the AEM even uses a commonly-available Fram element. You'd probably recoup your investment after 50,000 miles or so.
