Fuel Cut, Missfiring, "bucking"
Old 03-25-2009, 10:52 PM
connor53's Avatar
Default Fuel Cut, Missfiring, "bucking"
Alright, well. Last fall I parked my car, and it was running just fine. NO PROBLEMS whatsoever. Sat for months and wouldn't run right.
After diagnosing that it needed a new Coil because it had no spark at all she fired up.
Now the bad
While at idle it sounds normal. When giving it gas it misfires, backfires, and "pops", it kind of sounds like a car using it's "2-step"
Oh, also, the Rpms on the gauge cluster bounce around like crazy, and read NOTHING to what the car is actually at.
I've never not been able to figure a problem like this out before. Tried EVERYTHING I could think of. With no results. Checked the plugs, and replaced. Wires look fine. BRAND NEW Cap, Rotor, and Ignition Control Module. I'm all out of ideas.
Quick background.
Hondata S300, Peakboost Turbo Kit, 780cc Precision injectors w/resistor box, and walboro fuel pump.
Old 03-25-2009, 11:07 PM
mtber's Avatar
Default Re: Fuel Cut, Missfiring, "bucking"
Are you running factory honda ignition components i.e. cap, coil, icm & rotor ?
If not, get OEM parts!
I would suggest trying to find some one with a good distributor to borrow to test if the ignition system is your issue.
Old 03-25-2009, 11:10 PM
connor53's Avatar
Oem Cap and Rotor.
Got a steal on an Accel Coil from work. Don't believe it could be the ACCEL because it got the car running.
Icm started the car last year because the screw fell off the distributor rotor 2 years after I replaced the cap and rotor. Still confused about that. Completely rebuilt the distributor and it wouldn't start. slapped on a new one from a buddy's garage that he got from his J-spec B18c swap and the car ran for about 3 months. Then I parked it.
Old 03-25-2009, 11:23 PM
connor53's Avatar
If the Firing order is 1-3-4-2. Do I have the wire crossed?
Looking at the cap this is where each wire is going. I'm confused now, damn Haynes manuals. Underneath is how I have the plug wire routed.
23
14
4-3-2-1 (4 is closest to the distributor)
Old 03-25-2009, 11:51 PM
connor53's Avatar
Someone post a VERY visable picture of their plus wires and cap on their GSR please. I appreciate it so much. I've been whoring through the "integra pics" thread. And believe 2 of my wires are crossed.
Damn I feel like a noob. Never work on your car when it's pitch black out!
Old 03-25-2009, 11:53 PM
mtber's Avatar
Old 03-26-2009, 12:08 AM
connor53's Avatar
if their were neg reps and plus reps on here I'd accept 10 negs. and give you 10 mtber. God damn working in the dark really gave me the run around tonight. think that could be the problem?
Old 03-26-2009, 09:38 AM
connor53's Avatar
ok that was not the prob. thanks mtber any other ideas???
Old 03-26-2009, 11:48 AM
SlowB16si's Avatar
Have you put new gas in it or is this the same gas you had in it from last fall?
Old 03-26-2009, 06:11 PM
hmotors's Avatar
yeah we put new gas in it andy PM me your # buddy
Old 03-26-2009, 11:13 PM
connor53's Avatar
Ok after messing with the ignition all after noon we fried the new Accel coil and now have no spark again. running totally out of options! Someone please help me.
Old 03-27-2009, 08:56 AM
connor53's Avatar
Anybody got any ideas? I've got off of work all day and this is my mission to make this thing running!
Old 04-01-2009, 09:26 AM
connor53's Avatar
COME ON! Why can't anyone give a little bit of insight or help. Everybody has something to say about nothing. But then when a real problem arrises everyones quiet.
Old 04-01-2009, 09:39 AM
b20beast83's Avatar
my car will not start either
check fuses
Old 04-01-2009, 09:52 AM
totsie7944's Avatar
23
14
umm...looking at the firing order you posted, your wires are wrong on the distributor....yea are right about 1,3,4,2, however your wires are going to the wrong spot on the distributor according to this qoute..
Old 04-01-2009, 08:17 PM
connor53's Avatar
yea I know, I messed that up. They were actually right, the car wasn't at my house so I was guessing when I made the post online. But they were actually correct. Oops. I really wanna drive my god damn car. The dsmer's in my area are running their mouths lately, so I wanna see what I can do....but the car won't move so I get to say nothing.
Old 04-02-2009, 02:44 AM
wolve's Avatar
a friend of mine suddenly experienced cut out at low rpm sometimes and very frequently at high load/high rpm
pulled the plugs, had water in the plug holes.....
cleaned everything and put it back in
testrun---->same thing
changed out the distributor with mine (standing still for 6months but knew it worked)
changed out the plug wires with mine, had no hopes for it to work
testrun---->everything back to normal, so MSD's on the way
lesson, at least try to switch out with known good ones
GL
Old 04-02-2009, 06:40 AM
totsie7944's Avatar
I agreee......I'd toss in new plugs, wires, and dizzy and try that...if its still not working, I'd do a compression test and leak down test...see how your motor looks.
Old 04-02-2009, 09:14 AM
connor53's Avatar
hmm. Interesting. Well, new wires are being shipped in. Advance is warrantying out an ignitor for me. I Ohm metered the 3 crank sensors inside the dizzy, and the coil. Going to go for one final shot on friday to see what happens. If not I'm buying a new dizzy from work. Crossing my fingers and praying I get to drive the green monster around the block.
But I still need to find out what caused the dizzy to go bad in the first place.
Old 04-02-2009, 09:16 AM
LSXFEIND's Avatar
check ur TDC Sensor and wires for it is it throwing any codes?
LSXFEIND's Avatar
Sounds like its in limp mode!
Now the bad
Quick background.
Old 04-02-2009, 10:54 PM
connor53's Avatar
Just got paid, Advanced Auto Parts screwed me over on my igniter-icm. So I'm just going to pick up a new dizzy that I ordered from work today and throw it on. Really wanted to warrenty swap the igniter and see what happens since it failed on the autometer tester. But they really f-d up my plans on that. Didn't want to have to spend the 181 bucks on a new diz. But whatever. I omh metered the 3 sets of pin outs inside the dizzy. They all read 363 I believe. And the new dizzy I ordered up for myself read very similar. Oh well. We'll see what happens. I just couldn't understand why it was acting retarded. It sounded like a car running 2 step and the tach needle was jumping all over the place. I just wanna BOOOOOST!
connor53's Avatar
no codes btw. But I haven't hooked up my lap top yet to see what it says. Shame on me.
connor53
04-07-2009 06:44 PM
redskittle
03-01-2006 03:35 PM
shhh151
07-25-2005 03:47 PM
ogwutang
05-09-2003 12:11 PM
SleeperCivicEX99
09-09-2002 08:48 PM
Quick Reply: Fuel Cut, Missfiring, "bucking"
