fried ecu help! dont know what happend
Old Feb 5, 2006 | 10:07 AM
advert's Avatar
Default fried ecu help! dont know what happend
alright so last night my friend calls me and says he is stuck and his car wont start. so i go and try to help him. everyone is like hey try using your ecu in his car. so im like ok cant hurt. i pop it in he goes to start the car and smoke starts pooring out of the ecu. im like wtf and unplug it real quick. i try it back in my car its a no go. it starts the car but its running at like 20:1 AFR (i have a wideband mounted) and it sounds like its on to cylinders. so i try his ecu in my car and it works perfect. so what cause mine to fry and not his?
Old Feb 5, 2006 | 10:39 AM
EE_Chris's Avatar
Default Re: fried ecu help! dont know what happend (advert)
What ECUs are you dealing with here? "His" and "Mine" aren't too descriptive.
Old Feb 5, 2006 | 11:03 AM
boosted k20's Avatar
does ur friend have aftermarket injectors? if so does he have low impedance injectors and did he use a resistor box? most likely u fried ur inector circuitry in the ecu
Old Feb 5, 2006 | 04:23 PM
advert's Avatar
nope stock injectors. we both have p28's only difference is mine is chipped. we just want to get what ever is wrong with his fixed so there is no more fried ecu's
Old Feb 5, 2006 | 05:52 PM
xenocron's Avatar
Default Re: (advert)
Open the cover, take a pic of what is fried and that might help a little...
Old Feb 5, 2006 | 07:58 PM
advert's Avatar
i will take a pic. you cant see anything that got fried tho. it just smoked a LOT and it has that burnt smell to it. i dont understand. but i will take a pic 2morrow at work
Old Feb 6, 2006 | 06:42 AM
your friend might had his IAT sensor plugged into the purge solenoid and the purge solenoid switch plugged into the IAT sensor. this will fry the IAT circuitry
Old Feb 6, 2006 | 02:24 PM
advert's Avatar
Default Re: (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">your friend might had his IAT sensor plugged into the purge solenoid and the purge solenoid switch plugged into the IAT sensor. this will fry the IAT circuitry</TD></TR></TABLE>
i have this feeling that you are right. i am going to check his car tonight!
Matthewhughes
29
Aug 5, 2014 03:18 PM
97uswagon
Dec 18, 2011 07:49 PM
Boring
Dec 20, 2004 05:31 PM
H22CL
Jan 12, 2004 04:12 PM
