Fresh motor Compression test results
Old Jul 25, 2006 | 03:51 PM
HighRevn's Avatar
Default Fresh motor Compression test results
Just did a compression test on my freshy rebuilt gsr motor
160-155-170-165
this is on a gsr block b16 head with wiesco 9.1 pistons with 100 miles on it.
I dont know what to think, maybe its the crappy discount auto tester because sometimes it would fluctuate up or down 5%
And yes I did it WOT with the injectors and the fuse pulled...
Is this good or bad, could it be cause the rings havent fully seated yet?
another thing I noticed was air is pushing out the breather, theres no smoke but I thought the breather sucks in air?
Old Jul 25, 2006 | 04:02 PM
adseguy's Avatar
Default Re: Fresh motor Compression test results (HighRevn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HighRevn &raquo;</TD></TR><TR><TD CLASS="quote">
Nothing is official since you only have 100 miles. Drive it hard for another 500 and then do the test again. whatever method you use be extremely consistant. If you crank it over 5 times then do that for every cylinder.
A breather is attached to the valve cover....when you get gases that "blow by" the rings they come out there through a long process. It's totally normal and is even worse on a built engine. My car does it hard-core on the dyno with 26PSI
SpeedingHatch's Avatar
engine warm?
Old Jul 25, 2006 | 04:08 PM
HighRevn's Avatar
Default Re: Fresh motor Compression test results (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">
A breather is attached to the valve cover....when you get gases that "blow by" the rings they come out there through a long process. It's totally normal and is even worse on a built engine. My car does it hard-core on the dyno with 26PSI</TD></TR></TABLE>
wow thats good to hear, I going to the dyno next saturday, so is that normal with a new motor with so little miles on it?
HighRevn's Avatar
and yes it was done at normal operation temp
Old Jul 25, 2006 | 06:19 PM
HighRevn's Avatar
anybody else
Old Jul 25, 2006 | 06:24 PM
PyroProblem's Avatar
valves adjustment? May need to readjust after everything breaks in...
Is it using any oil?
Old Jul 25, 2006 | 06:36 PM
HighRevn's Avatar
Default Re: Fresh motor Compression test results (PyroProblem)
just did a adjustment, not eating any oil
Old Jul 25, 2006 | 08:01 PM
earl's Avatar
Check it again after the dyno. It should be a little more even by then.
Old Jul 25, 2006 | 08:03 PM
komat's Avatar
Default Re: Fresh motor Compression test results (earl)
before i went to the dyno
i could only get 160psi with my lsvtec 9:1
after i got it tune
now its at 180
Old Jul 25, 2006 | 08:17 PM
Muckman's Avatar
Moderator in Chief
Keep a log of your compression test results. And try to always conduct the test the same each time. I found that my compression numbers still rose until the 750~1,000 mile mark.
Old Jul 26, 2006 | 08:24 AM
HighRevn's Avatar
Default Re: Fresh motor Compression test results (Muckman)
thanks guys, I appreciate it
Boosted Chemist
May 4, 2007 06:33 AM
B18EG6
Jan 29, 2006 02:24 AM
RAS Motorsports
Dec 10, 2003 05:16 AM
RedRacerCivic
11
May 22, 2003 10:29 AM
gsr~hatch
Apr 17, 2003 03:19 PM
