FPR with FMU
Old May 10, 2002 | 10:35 AM
b18tdelsol's Avatar
Default FPR with FMU
Hey, do i need to adjust the aftermarket FPR if i'm using a FMU? Like, if i turn up the pressure on the FPR, and my FMU is 12:1 then, overall..thats more fuel right? From what i'm thinking, i just need to adjust the fpr for when it's 0 boost right? Then from there on, the fmu just takes over right?
Old May 10, 2002 | 11:28 AM
RGAZ's Avatar
New User
Default Re: FPR with FMU (b18tdelsol)
You are correct. The FPR will adjust fuel from 30 "/Hg to 0 "/Hg and the FMU will adjust from 0 psi to whatever. The FPR will raise the pressure with boost, but at a rate much less than the FMU, so it is negligible.
So to set the FPR, disconnect the vacuum line and adjust it.
Randy
98GSR-Turbo
Dec 18, 2007 07:40 PM
petarr
Sep 11, 2005 02:07 PM
SuperRex
Jul 5, 2004 09:03 AM
xstalkrx
Jul 17, 2003 11:01 PM
KTeller8
Jun 3, 2002 11:43 AM
