which fpr?
i searched but didnt find anything under fpr or fuel pressure regulator. for my fuel i have a walboro 255 and getting rc 550cc's and hondata. i was wondering what fpr to run? would a aem be fine? thanks for the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si »</TD></TR><TR><TD CLASS="quote">will stock really work with the pump and the 550 injectors? how can you raise the fuel pressure with the stock one?</TD></TR></TABLE>
I am under the impression that with Hondata there isn't really a need for one. I could be and am probrably wrong though.
-Ryan
-Ryan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PH_B16-VTi »</TD></TR><TR><TD CLASS="quote">When using Hondata, you keep the base presure and get bigger injectors and adjust the fule map in the hondata.
/PH</TD></TR></TABLE>
Not exactly true, you get the benefit of actually running a lower fuel pressure with the Hondata and not having the injectors at 100% duty cycle so quickly as with stock fuel pressure settings.
I reccomend (and so does hondata) getting a true 1:1 rising rate fpr.
I run the Aeromotive...
BTW, the stock regulator isnt 1:1 as many other tuners on this board can telll you.
I believe i got mine from http://www.Jegs.com
I know it comes with some hardware, but it's been over a year since i bought mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoustonSi »</TD></TR><TR><TD CLASS="quote">
BTW, the stock regulator isnt 1:1 as many other tuners on this board can telll you. </TD></TR></TABLE>
Oh really? So you apply one pound of pressure to the spring and some how that isn't one pound? You apply two pounds and that isn't two pounds? ETC...
Please enlighten me.
I run B&M only to play with fuel pressure to fine tune my direct port setup else I would keep it stock.
It's been covered and debated...
https://honda-tech.com/zerothread?id=93758
I noticed the same thing on my 00 Si.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoustonSi »</TD></TR><TR><TD CLASS="quote">It's been covered and debated...
I noticed the same thing on my 00 Si.</TD></TR></TABLE>
Thanks for the link
Thanks for the link
