Forge pistons...noisier?
Old Aug 28, 2002 | 04:44 PM
  #26
OKSolSi's Avatar
Default Re: Forge pistons...noisier? (earl)
I say its just your fuel injectors clicking. With a stethescope on any engine with fuel injection, you will hear that clicking noise. The reason it doesn't do it at high/higher RPM is because there is enough flow going through your fuel injectors for them to not have to sporadically pump so slow, thus you don't hear it.
Old Aug 29, 2002 | 10:35 AM
  #27
pornstarSR's Avatar
Default Re: Forge pistons...noisier? (OKSolSi)
Ohhh my lord this topic is getting out of hand...
Forged pistons =
slower or later heat expansion
clearances are alittle(and when i mean little i mean little)loose when cold
sounds like a diesel, or a clatter
yes its scary
yes its normal
injectors can make that noise but its a tad bit different
should you worry about it
NO
not unless you start hearing that chatter while driving. then you need to worry
if you trust how you put together the motor and you used plastigage and checked all the tolerances then you should be good.
just remember the pistons arent stock, they are not going to behave like stock pistons, since they are made out of different materials they will do different things.
and forgive me if im getting crazy here, im sick so a tad bit edgy.
i just see all the time in here people just start talking smack trying to be the one that one ups someone else....im not saying im right by any means, but i have some experience. I do not know anyones elses experience level and no one knows mine, so just answer the questions
[Modified by pornstarSR, 7:38 PM 8/29/2002]
Old Aug 30, 2002 | 12:54 AM
  #28
vtectuner99's Avatar
Default Re: Forge pistons...noisier? (SO3Burner)
same i have a fully built d16y8 and its noisy when i start my civic but it goes away within minutes
.dave
Jun 15, 2006 06:09 AM
GreddySi99
Sep 27, 2003 10:38 AM
94RS
Sep 15, 2002 03:20 PM
GruvyTune
Aug 27, 2002 09:47 PM
Trajic
Nov 15, 2001 05:08 AM
