JE pisotns rattle alot?
New User
Ok just got some JE pistons installed and they rattle alot whent he car cold but at soon as it warms up it stops. they told me that was regular becouse je pistons anre cold pistons and that they get bigger with heat. I thought they overbored my sleeves. should i worry
Re: JE pisotns rattle alot? (Trajic)
mine did the same thing. They made a knock knock noise. I was also told this is a normal noise so i never worried. Although i broke my pistons when my fuel computer broke at 16psi of boost and the car went super lean. But i still got 10,000 miles on the motor before that happened without problems.
liam
liam
je's have floating wrist pins,this is some of your noise. pressed pins are quieter but rob horsepower. dont worry
Re: JE pisotns rattle alot? (speedworks)
I have heard about people who had trouble with cyls who wears out of specs fast with JE`s is this commond or have i listen to the wrong people??
ps he used Total seal rings,can that be the reason?
Re: JE pisotns rattle alot? (Davy Crockett)
Total seal rings absolutely suck, Don't get me started on them again. I've never seen bigger pieces of trash.
New User
Re: JE pisotns rattle alot? (GSRacer)
My engine has no internal work done to it and it sounds like that (semi truck, deisel sound). I just did a valve adjustment so, I know it wasn't that. The car pulls really good and sounds good when I rev the engine up, but just has that knocking sound. I only have I/H/E. Should I have a real mechanic take a look at it? or don't worry. The car only has 23k miles right now. Thanx in advance
Re: JE pisotns rattle alot? (Confuishus)
I can still hear it after driving for a while. I can only really hear it when the car is at a standstill.
art
The knocking noise might be caused by piston slap b/c of the loose tolerances that the pistons have with the cylinder bore. This happens b/c of the metallurgy of the pistons, which are lower in Silicon(e)? content than the stock cast slugs. They fluctuate in size more with temperature than a high Silicone slug causing the tolerances to loosen up when the engine is cold and then tighten up when the engine warms up.
Is it normal to see a little blow by from the valve cover breather with JE pistons? Some days I see more than others.
Cant see how this can make noise.My engine has also floathing wrist pins (stock pistons) buyt i have no noise at all.
Re: JE pisotns rattle alot? (Damon501)
ok...if this sounds dumb u all can flame me...but...could it be your valves knocking? because i thought that they make noise when you start up the car but as your car heats up the valves expand...so then it stops...is it the same with pistons? or am i just a big dumbass?
Forged pistons "clack" until they warm up. They expand slightly as they heat up. I've always run big nitrous shots on my domestic motors and considered forged pistons a necessity. I have never had any premature wear cause by the pistons
[Modified by mplex2000, 11:35 AM 11/15/2001]
Re: JE pisotns rattle alot? (IN VTEC)
As mentioned by everyone it is due to thermal expansion, cold - these pistons have a slightly smaller circumference until they reach engine operating temperature, it is important that if you run these pistons with a standalone computer that you have a good short (lean) warm up enrichment to get them up to temp faster, the slapping can hurt your bores a bit and remove the hone work.
Silicon is not a metal, it is sometimes grouped with elements like Sulfur and Phosphorus as a "metaloid".
GreddySi99
09-27-2003 10:38 AM
