fluidampr install problem
Old Jan 2, 2006 | 10:37 AM
Mikey3000's Avatar
Default fluidampr install problem
i went to install my fluidampr pulley and it seems that there is not enough room for it. I have a H22A in a Civic HB (Hasport mounts) and the problem lies in the thickness of the pulley. the space between the right side of the motor and the framerail doesn't seem to be big enough to fit this thing.
anyone install one on a H22/Civic before or have any insight?
thanks.
updated 1/03/06: see below
Modified by Mikey3000 at 6:40 PM 1/3/2006
Old Jan 2, 2006 | 10:43 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: fluidampr install problem (Mikey3000)
That just plain out sucks ***. You dont have AC or PS I am assuming.
Old Jan 2, 2006 | 10:49 AM
Mikey3000's Avatar
Default Re: fluidampr install problem (White Smoke)
nah i dont have AC or PS.
Old Jan 2, 2006 | 11:06 AM
alpha's Avatar
Are you able to take pictures? Maybe we can give you some ideas.
Old Jan 2, 2006 | 11:09 AM
SFWD 1934's Avatar
Default Re: fluidampr install problem (0x64)
Sometimes if there as been any front end damage before on the vehicle there is a bit of an issue, because there is not a lot of room to begin with. Anyways the way that I have used to rectify that is remove the timing belt side mount, and lower the motor down on that side just below the lip of the frame rail to get the clearance that I need.
Jason
Old Jan 2, 2006 | 11:18 AM
Mikey3000's Avatar
Default Re: fluidampr install problem (SFWD 1934)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFWD 1934 &raquo;</TD></TR><TR><TD CLASS="quote">Sometimes if there as been any front end damage before on the vehicle there is a bit of an issue, because there is not a lot of room to begin with. Anyways the way that I have used to rectify that is remove the timing belt side mount, and lower the motor down on that side just below the lip of the frame rail to get the clearance that I need.
Jason</TD></TR></TABLE>
thats what I was going to try. so when you brought the motor back up and put it in place, there was clearance between the pulley and frame rail? i tried to measure and it seems like it could work but i cant seem to get an accurate measurement cuz its a tight squeeze.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">Are you able to take pictures? Maybe we can give you some ideas.</TD></TR></TABLE>
yeah i could take pics if the idea above doesnt work.
Old Jan 2, 2006 | 11:55 AM
i my honda
Global Mod
Email Fluidamper about this and see if they have any info.
Old Jan 2, 2006 | 12:02 PM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">Email Fluidamper about this and see if they have any info. </TD></TR></TABLE>
good idea, i'll do that.
Old Jan 2, 2006 | 12:43 PM
93H22ACX's Avatar
keep us updated... im planning on getting one soon also
Old Jan 2, 2006 | 12:49 PM
richeybrooks's Avatar
its hammer time!!!!!!!!1
Old Jan 2, 2006 | 02:22 PM
SFWD 1934's Avatar
Default Re: fluidampr install problem (richeybrooks)
No afterwards there was ample clearance. If you email Fluidampr, chances are they will call me and ask me about it.
Jason
Old Jan 2, 2006 | 04:20 PM
fastforwardracer's Avatar
same problem on r 98 coupe. we are either gonna cut the frame rail or fabricate some different mounts. axle angles are not the best byno means.(hasport now)
Old Jan 2, 2006 | 05:45 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: fluidampr install problem (fastforwardracer)
Assuming you have the race, it will not fit. Its very possible the street version will fit without the ac and ps pully removed.
The same goes for the B-series in an EF, you have to run a street because the race wil not fit.
art
Old Jan 2, 2006 | 05:59 PM
93H22ACX's Avatar
Default Re: fluidampr install problem (Arturbo)
thanks art
Old Jan 3, 2006 | 05:16 AM
Mikey3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Assuming you have the race, it will not fit. Its very possible the street version will fit without the ac and ps pully removed.
art</TD></TR></TABLE>
great. so will the street version fit WITH ac/ps pulley removed? i don't have ac/ps.
Old Jan 3, 2006 | 09:09 AM
Arturbo's Avatar
Better than steak
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">
great. so will the street version fit WITH ac/ps pulley removed? i don't have ac/ps.</TD></TR></TABLE>
with that setup, h22 in your chassis I am not 100% sure but I am going to say yes since its the same size as the stock pulley.
art
Old Jan 3, 2006 | 02:42 PM
Mikey3000's Avatar
ok, i dropped the driver side of my motor and got the pulley installed on the crankshaft, all the way in. I go to jack the motor back into place, and there's about 3/16" of overlap of the pulley on the framerail. so unbelievably small. so, what do you think of cutting a notch out of the framerail? i checked fluidampr's website and it seems as though they don't have a street series pulley for the H22a.
Old Jan 3, 2006 | 03:15 PM
Arturbo's Avatar
Better than steak
25 Year Member
yeah sorry, they dont make a street. Sorry. But looks like you are going to have to beat the frame rail.
art
Old Jan 3, 2006 | 03:37 PM
Mikey3000's Avatar
do you think beating will be easier than cutting?
Old Jan 3, 2006 | 03:55 PM
Jared's Avatar
I beat the frame rail in my crx to fit the race pulley.
Old Jan 3, 2006 | 06:15 PM
speedworks's Avatar
Default Re: (Jared)
mine fit, but i have the engine mounted closer to the front of the car. just notch the rail and cap it back in.
Old Jan 3, 2006 | 06:19 PM
Mikey3000's Avatar
Default Re: (speedworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote"> just notch the rail </TD></TR></TABLE>
thats what i'm gonna do.
SFWD 1934
May 17, 2012 10:15 AM
973 Jdm Kid
Nov 13, 2009 08:14 PM
Mikey3000
Jan 2, 2006 07:21 AM
dcdcdc
Jun 3, 2005 09:03 AM
BigDawwg6969
Jan 18, 2004 02:35 PM
