AN fittings- weld on, metals, method
Old Apr 28, 2016 | 05:29 AM
bergercurtis's Avatar
Default AN fittings- weld on, metals, method
Hello all,
Not much of a welder myself, though I have tinkered with friends TIG and MIG machines a bit. That being said, I am ordering some AN fittings for a turbo build. I would like your take on what metals, methods, and tips would be best for success. The engine is a D16Z6- stock aluminum valve cover.. I believe the oil pan is aluminum as well. I will be welding two fittings onto the valve cover and one return line fitting into the pan. Open to suggestions on where to get quality fittings as well if anyone has recommendations. I'm thinking about ordering premade, proper length hoses already compression crimped to avoid the hassles of fraying and poor sealing ends. Let's hear it. Thanks.
To any moderator: I did post on this topic within the welding/fabrication forum as well, but think I'd have more support and activity within the FI forum.
Old Apr 28, 2016 | 10:01 AM
B and B's Avatar
Loved
Community Favorite
Default Re: AN fittings- weld on, metals, method
The pan on a stock Z6 is steel. So u will need 1 steel weld on fitting for that, and the two aluminum for the vc.
Jegs or wherever, take your pick..they have all prices.
I like the idea of the crimped hoses, or push-loc.
Old Apr 28, 2016 | 12:15 PM
2kdrift's Avatar
yup Z6 pan is steel unless it was swapped to a Y8 Pan (possibility)
B&R Fittings Best prices, I get alot of stuff from him quality is excellent and cust service is top notch
bergercurtis
Welding / Fabrication
May 1, 2016 01:01 PM
90Rexx
May 28, 2010 08:20 AM
pitoracing24
Dec 4, 2007 04:05 PM
albsgsr
Jun 15, 2005 11:30 PM
B16CRXT
Apr 15, 2005 07:14 AM
