14b oil return/feed questions
Old Jul 22, 2003 | 04:45 PM
sk8rmike's Avatar
Default 14b oil return/feed questions
ok, im using a 14b on my z6 turbo project. question is, does anyone know the fitting size for the return? also, i have the stock feed line banjo fitting, should i use that, or use an NPT fitting?
Old Jul 22, 2003 | 06:08 PM
sk8rmike's Avatar
Default Re: 14b oil return/feed questions (sk8rmike)
bump
Old Jul 22, 2003 | 07:54 PM
Flamenco-T's Avatar
Most return on 14B used a steel tube drain flange from the factory.
On the oil feed you can use an inverted flare to -3AN fitting and run a -3AN for the feed line. I sell complete kits for 14B for both oil feed and oil return.
PM me if intersted in pricing
stan
stan@fast-turbo.com
hondaeg8
May 23, 2006 11:53 AM
88da3
Feb 1, 2006 03:47 PM
D3LSLO
Mar 21, 2004 08:20 PM
Prelude91siT
Jan 19, 2004 06:24 AM
Del_Slowest
Nov 27, 2003 09:07 AM
