First time to the dyno
Old Nov 26, 2001 | 12:10 PM
98Psi ITR's Avatar
Default First time to the dyno
1.0 Bar
Stock head, stock cams, stock cam settings, built bottom end w/ 9.0:1
270hp
197tq
Those are the numbers uncorrected. I think the hp was 322 corrected.
What do you think?
Old Nov 26, 2001 | 12:17 PM
Liltrix's Avatar
Default Re: First time to the dyno (98Psi ITR)
thats good
Old Nov 26, 2001 | 03:07 PM
DIRep972's Avatar
Smarter than you
for 1.0 bar.. is that really good? is corrected hp at the flywheel or is it just corrected for elevation temperature and etc.. 322 is good at the wheels but you shoud be making alot more..
Old Nov 27, 2001 | 09:34 AM
98Psi ITR's Avatar
Default Re: First time to the dyno (DIRep972)
it was 270whp and 322whp corrected for sea level. I live about a mile high.
[Modified by 98Psi ITR, 10:35 AM 11/27/2001]
Old Nov 27, 2001 | 09:53 AM
FAST94GSR's Avatar
New User
sounds great, get you some slicks and go hit the strip!
Old Nov 27, 2001 | 10:27 AM
InfamousDX's Avatar
great numbers there. i would actually expect a little more than 320 whp from 1 bar though.
Old Nov 27, 2001 | 12:06 PM
98Psi ITR's Avatar
Default Re: First time to the dyno (InfamousCivic)
I'll be back once I get the test pipe in. I think we can get 350, I hope...
Old Nov 27, 2001 | 02:29 PM
FAST94GSR's Avatar
New User
is your engine tuned?
Old Nov 27, 2001 | 03:13 PM
98Psi ITR's Avatar
Default Re: First time to the dyno (FAST94GSR)
only thing i can adjust is the fmu and the vafc for tuning. still looking for a stand alone. the fuel curve was damn near perfect around 12.5, but i can't check the duty cycle for the injectors...no instrument . I'm gonna go no higher than 18psi with these injectors for sure that'd be max'ing out.
[Modified by 98Psi ITR, 4:19 PM 11/27/2001]
Old Nov 27, 2001 | 06:07 PM
SiRkid's Avatar
what size?
Old Nov 28, 2001 | 04:38 AM
98Psi ITR's Avatar
310cc's, I know they are small and prolly running at max now. I'd like to upgrade to 550's and not so high a fuel pressure under boost.
Old Nov 28, 2001 | 05:05 AM
ForcedAccord's Avatar
Texas B*tch!
I was going to say, shouldn't you upgrade injectors?
kartman5
Honda Civic (2006 - 2015)
16
Mar 11, 2010 01:59 PM
rev-speed
Jan 6, 2005 11:16 AM
TheShocker
Sep 16, 2003 08:15 AM
austrian type-R
Apr 22, 2002 12:40 PM
austrian type-R
Apr 20, 2002 08:14 AM
