first gear sucks!
so starting at a stop, first gear feels like i am starting in second gear until i hit boost, it just feels really booged down. anyone have any suggestions? its a d16z6 with a t3
thanks
thanks
i know this sounds stupid but if the roll pin in your shift linkgae is allowing too much play it may feel like your putting it in first but youll be in third. i did this when i did my first swap and couldnt figure out what the problem was.
just a suggestion...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5litereater »</TD></TR><TR><TD CLASS="quote">i know this sounds stupid but if the roll pin in your shift linkgae is allowing too much play it may feel like your putting it in first but youll be in third. i did this when i did my first swap and couldnt figure out what the problem was.
just a suggestion...</TD></TR></TABLE>
hahahaha, man, that would be a BIG bog. I dont even think I could start in 3rd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx »</TD></TR><TR><TD CLASS="quote">
hahahaha, man, that would be a BIG bog. I dont even think I could start in 3rd</TD></TR></TABLE>
No ****! I doubt it's that. If the tune is bad then it should do this in all gears at the same rpm. Make sure it does this at the same rpm for all gears....it really should because i don't see what else it could be
well the timing should be stock, i am using uberdata and pre boost i never touched, does anyone noticed what they are sitting at when they first start moving? to me, it looks like i am at 0 vac. i dont know if that makes a difference
yes i have a wideband
and the NON boost portion of the stock map was not touched
should i lighten up the non boost section? if someone has how much did you?
Modified by Btothe3rdDegree at 12:53 AM 3/2/2005
What size injectors are you running? large injectors + uberdata usually results in fruity low-load response if you are running closed loop (off otherwise unmodified base maps). You running closed loop?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Btothe3rdDegree »</TD></TR><TR><TD CLASS="quote"> i got lower compression pistons so i will add more timing
Bam...theres your problem...
</TD></TR></TABLE>Bam...theres your problem...
