first engine build
Old Feb 18, 2010 | 08:44 PM
djustice_tn's Avatar
Default first engine build
Hey guys,ive been reading and researching thread after thread here on HT for the past few months and now ive come to the point where i feel confident to begin an engine build.I want to build a reliable 400-500hp LS-turbo dd/occasional drag strip car.I know its been covered a million times but im not asking how to build it,i just need some guidance along the way and your guys input on what will and will not work.
This is going to be a very slow build.As of right now i have a 99 LS head that i plan on taking to the machine shop.I have everything out of the head.It is stained with burnt oil and id like to clean it up to thoroughly inspect it for wear and cracks...Any suggestions on how to clean it up?The valve guides seem fine theres no play or wobble in them should i upgrade them or will they be fine for my power goal?
Here are my plans for the head-any input appreciated
-full port & polish
-3 angle valve job
-(?) cam gears
-Crower stage 2 turbo cams
-Crower dual valve springs & titanium retainers
-Crower ss 31.5mm intake valves (+.5mm)
-Crower ss 28mm exhaust valves (standard)
-IL4 bronze valve guides.... or ?
-RC 1000cc injectors
-Edelbrock Victor X im
-70mm throttle body
-AEM fuel rail
-Hondata intake manifold gasket
-multi layer cosmetic head gasket
-cam seal
Old Feb 21, 2010 | 05:33 PM
Default Re: first engine build
input anyone??
Old Feb 21, 2010 | 06:02 PM
WHEELS845's Avatar
it sounds good so far just don't rush and make sure to use proper torque spec for your bolts.
Old Feb 21, 2010 | 08:13 PM
Scott_Tucker's Avatar
You should have the machine shop clean the head. Thats not something you can do properly at your house. Any gunk that might get left in the oil passages will come out after you reassemble it and destroy your new engine. You should have the guides checked and serviced if necessary by the machine shop. The 'wobble test' is inaccurate and won't tell you anything. If your guide clearance is excessive the seals will be useless in keeping oil out.
Also, you say you plan on installing larger valves. Do you plan on having larger seats installed too, along with the port work necessary to make that mod worthwhile?
Old Feb 21, 2010 | 08:48 PM
iamthefollower's Avatar
Goodluck on the build, I hope you post pics and everything as you go.
Old Feb 22, 2010 | 01:38 PM
thx..ok ill have the machine shop clean the head and check it out and make sure its ok. Good point on the larger seats i didnt think of that...do you think it would be worth installing larger intake valves or would the stock size be sufficent? I mean its just .5mm...dosent seem like much.
Old Feb 22, 2010 | 01:39 PM
Thanks i'm taking plenty of pics maybe too many.Ill post some soon
Old Feb 22, 2010 | 02:17 PM
Honestly, I wouldn't bother on your first build. Who told you this was a good idea anyway? Its a lot of work for very little gain. You would be better off having the head ported with the stock valve size and will probably see better flow gains anyway. By installing larger valve seats you risk altering the venturi under the valve seat which is very important for airflow past the valve.
Old Feb 22, 2010 | 02:32 PM
No one really told me to do it that way,just usualy when i see high horsepower builds most of the time they use larger valves.Sounds good to me...i have no problem saving some $$
Old Feb 22, 2010 | 02:51 PM
boostedEF91's Avatar
x2. no need.
Old Mar 1, 2010 | 01:16 PM
head is @ the machine shop....pics soon
Old Mar 4, 2010 | 08:21 PM
[ATTACH][ATTACH]Name:  010.JPG
Size:  89.6 KB[/ATTACH][/ATTACH]Name:  002.JPG
Old Mar 4, 2010 | 08:30 PM
Ok..im trying to vent the valve cover...do i need to make the holes the inside diameter of the bungs and weld the bung on or make the holes the outside diameter of the bungs and weld them on??? i didnt drill through the baffle
Old Mar 5, 2010 | 01:00 PM
bump on what size holes to put in the valve cover
Old Mar 5, 2010 | 01:27 PM
wunfstgsr's Avatar
Loved
Community Favorite
Why not ls-vtec??
https://honda-tech.com/forums/showth...eliable+lsvtec
Old Mar 5, 2010 | 02:40 PM
Originally Posted by wunfstgsr
i just wanna do a straight ls turbo
Old Mar 14, 2010 | 01:44 PM
I got the valve cover back from welding and it turned out great.
I did come cutting on the cam gear cover and painted it with some VHT wrinkle paint.
Old Mar 14, 2010 | 01:50 PM
I had some spare time on my hands and had some EK door panels laying around so i thought i would try and typeR them.
Keo00civic
Jan 30, 2014 02:20 PM
Prudz_lude
Oct 1, 2012 11:37 AM
lilrobie69
Feb 7, 2011 08:45 AM
boosted94cx
Apr 20, 2006 09:30 PM
TurboTeG4
Oct 1, 2003 10:16 PM
