first dyno pull
Old May 22, 2002 | 03:29 PM
dxman's Avatar
Default first dyno pull
first pull after turbocharging my dx with a mitsu 14b homemadeturbo heheh
topped off at a wimpy 132 whp and 130 lbs of tourqe. I really need a fuel
pump cause there was mad detenation after 5500 rpms. Dont have a scanner
otherwise i'd post up the charts. I think its pretty decent considering the stock
1.6 non vtec engine puts out less than 100 whp..... what do you guys think?
or
Old May 22, 2002 | 03:47 PM
SlowB16's Avatar
Default Re: first dyno pull (dxman)
do you have any sort of fuel upgrade? ie - an fmu
Old May 22, 2002 | 06:00 PM
dxman's Avatar
Default Re: first dyno pull (SlowB16)
yea a 12:1 with a b&m fpr
stock injectors, internals
need $$$
Old May 22, 2002 | 06:06 PM
OKSolSi's Avatar
or
Holy **** dude thats the weakest **** that I have ever seen. How many PSI are you boosting? Your car would get walked on by my stock del sol si.
Old May 22, 2002 | 06:11 PM
Etylorcen's Avatar
Default Re: first dyno pull (OKSolSi)
Actually thats pretty damn good if you consider the dx has 103hp at the flywheel stock. Thats like 50-60 more hp than stock.
Old May 22, 2002 | 06:12 PM
LEON's Avatar
I think it's pretty good considering... if his car stock puts down 100whp an increase to 132whp is pretty significant with a relatively small 14b turbo. I say good job, but fix that detonation and get it tuned as I'm sure it would be much better, say 150whp @ ~12psi
What boost are you running?
dxman's Avatar
hah ur funny.....just remember that i started with a weak *** 90 hp engine
i was at 5psi. ultimate goal is to make 200 whp
hahahahhaha
Old May 22, 2002 | 11:27 PM
inspyral's Avatar
You'll probably solve your detonation problems by getting an inline fuel pump. That FMU isn't getting the flow it needs to maintain high fp under boost.
ej8
Jul 30, 2007 03:20 AM
ef8b16a1
Jun 26, 2005 11:23 PM
Slava.
Mar 16, 2004 08:41 PM
spooled b16
Apr 30, 2003 02:08 PM
rbf351
Dec 12, 2002 10:40 AM
