First Dyno ever
This afternoon was my first dyno session. I need your thoughts. My setup is:
Drag mani
Turbo (GT3255E)
tial 38mm wastegate(8psi spring)
rc550's
Custom fmic
greddy type s bov
Hondata S200
drag ic piping
walbro 255 fuel pump
drag 2.5" dp
for now a stock itr exhaust
I made 242.0whp with 169.2ft/lbs @ 8psi
Tell me what you think.
Drag mani
Turbo (GT3255E)
rc550's
Custom fmic
greddy type s bov
Hondata S200
drag ic piping
drag 2.5" dp
Yes. It's a great all around turbocharger that's not going to break the bank
You can turn up the boost some more but I am sure you are happy with it as is. The exhaust, along with a couple other things, is hurting your torque and horsepower but as I said above you should be happy for now.
I want to turn up the boost a bit I am looking for a 10psi spring right now. This dyno is a mustang dyno, and I heard that you have to add a bit more power to get the equivelancy of a dynojet. Is this true?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tapen00n »</TD></TR><TR><TD CLASS="quote">torque is low because you have no cat, more flow means less backpressure</TD></TR></TABLE>
lol, no. Backpressure has nothing to do with it, backpressure has nothing to do with it in an N/A car. If anything having no cat would make more torque, because the turbo would spool quicker.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRT »</TD></TR><TR><TD CLASS="quote">This afternoon was my first dyno session. I need your thoughts. My setup is:
Drag mani
Turbo (GT3255E)
rc550's
Custom fmic
greddy type s bov
Hondata S200
drag ic piping
drag 2.5" dp
Tell me what you think. </TD></TR></TABLE>
242hp at 8psi on a GSR motor is really low? If it's on a LS then that's about right
Drag mani
Turbo (GT3255E)
rc550's
Custom fmic
greddy type s bov
Hondata S200
drag ic piping
drag 2.5" dp
My tuner said that if I ditch my piece of **** exhaust and put 3" piping it will be a dramatical increase in hp. he said around 10hp. as well it's on a conservative tune so the timing is not too advanced. He put it for a very streetable tune, not too aggressive. I'll go back with my new setup and then we will see.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benjithx »</TD></TR><TR><TD CLASS="quote">if you only had a stronger block......
sorry, I am itching for an STI</TD></TR></TABLE>
Funny. I'll just mess around with this one till she blows and then buy a built block. Dont worry Benjithx you'll sell it, There are plenty of people who need a sleeved block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo »</TD></TR><TR><TD CLASS="quote">
242hp @ 8psi on a GSR is not low on a Mustang Dyno.
</TD></TR></TABLE>242hp @ 8psi on a GSR is not low on a Mustang Dyno.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo »</TD></TR><TR><TD CLASS="quote">you might free up some more hp if you get a better exhaust. Was that dyno with a stock catylac convertor?</TD></TR></TABLE>
might? WTF....that right there would be like a 20whp gain.....
Awsome man...
But I'm also betting money that you don't see 8si by 3000rpm's with that exhaust and 2.5" Downpipe......
Awsome man...
be carefu wid ur a/f ratio if u change the exh, if it makes a big difference flow wise and if it hurting u so much now, u can bet it will effect the a/f ratio dramatically.
-Toby
-Toby
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 »</TD></TR><TR><TD CLASS="quote">Yes. It's a great all around turbocharger that's not going to break the bank
You can turn up the boost some more but I am sure you are happy with it as is. The exhaust, along with a couple other things, is hurting your torque and horsepower but as I said above you should be happy for now.</TD></TR></TABLE>
Arent these turbos around 750.00 new?
You can turn up the boost some more but I am sure you are happy with it as is. The exhaust, along with a couple other things, is hurting your torque and horsepower but as I said above you should be happy for now.</TD></TR></TABLE>Arent these turbos around 750.00 new?
mustang dyno = 3-4 % less then dynojet
my dyno (b18c, eagle rods, stock comp je pistons, drag kit @ 10psi)
279 whp @ 7200 rpm
218 ft lbs @ 6800 rpm
best time so far is 11.7 @ 116 mph w/ my girlfriend in the car video tapping
the track is open tonight, hopfully better times today....
this is in a 89 crx si
(15 x 24.5 welds)
the car went 11.9 @ 113 w/ 8psi with the stock motor last year, finally blew after 2 years....
was only making 235 whp and 181 ft lbs on a dynojet ( rings were going)
279 whp @ 7200 rpm
(15 x 24.5 welds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">
But I'm also betting money that you don't see 8si by 3000rpm's with that exhaust and 2.5" Downpipe......</TD></TR></TABLE>
I will double check,
but I'm pretty sure it's not many more rpm if any.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TuRbO_CrX_7o2 »</TD></TR><TR><TD CLASS="quote">mustang dyno = 3-4 % less then dynojet</TD></TR></TABLE>
Mustang Dyno can do unloaded (Dyno Jet) numbers. I have found a 5% - 7% difference in power between loaded and unloaded pulls on a Mustang Dyno. It seems like people on here think Dyno Jet's are superior to Mustang Dyno's
