fine 2 drive on basemap?
Old May 5, 2007 | 11:35 AM
TcUiRvBiOc's Avatar
Default fine 2 drive on basemap?
i just got a basemap for a stock gsr with dsm 450's from intec 2 start my car and drive it 2 get it tuned, but im not sure if i will get it tuned this weeken and need 2 drive it... can i drive it around as long as i dont hit full boost?
Old May 5, 2007 | 11:47 AM
adseguy's Avatar
Default Re: fine 2 drive on basemap? (TcUiRvBiOc)
You can drive on it, just don't hit ANY boost. I always put a boost cut at 2 psi for my basemaps, but if you don't get more then 50% on the throttle there shouldn't be a problem.
Old May 5, 2007 | 05:10 PM
HamiltonRex's Avatar
Default Re: fine 2 drive on basemap? (adseguy)
yeah i drove around on a basemap for 3 weeks, just dont get on it.
Old May 5, 2007 | 06:41 PM
CivicVX94's Avatar
Default Re: fine 2 drive on basemap? (HamiltonRex)
I drove around for a few days on a basemap but I had a fuel cutout at 2psi so i couldn't get on it or overboost...
Old May 5, 2007 | 08:20 PM
bigbadboy's Avatar
yep been drving on mine for a while. have the boost cut on my s300 set at 1
Old May 5, 2007 | 09:16 PM
TcUiRvBiOc's Avatar
Default Re: (bigbadboy)
how do u set a boost cut?
Old May 6, 2007 | 02:14 PM
CivicVX94's Avatar
Default Re: (TcUiRvBiOc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TcUiRvBiOc &raquo;</TD></TR><TR><TD CLASS="quote">how do u set a boost cut?</TD></TR></TABLE>
idk Blundar did my tuning with Crome...pm him I'm sure he'd help you out
Old May 6, 2007 | 02:17 PM
Schister66's Avatar
Man U FTW
Drive nice and you wont have any problems....i drove on my basemap for about 2 months before i got tuned....another thing you can do to prevent yourself from blowing it up is to get plugs w/ a large gap (.4 or so) and that way you will blow the spark out before you do any damage....just another safety precaution
Old May 12, 2007 | 11:23 PM
dubzz24's Avatar
Default Re: (Schister66)
Maybe a noob question, but I don't understand what is so bad about driving on a properly set basemap. If you richen up the boost fuel maps, and set an ignition retard (-.6* per pound or so), it should be pretty safe. If anything the only thing you'll do is foul some plugs from running too rich, or just not make as much power as you could. As long as you keep the boost somewhat low (8~ psi).
I'd think it would be much safer than an FMU or AFC hack since at least you have the ignition control too.
Someone enlighten me
Old May 13, 2007 | 03:49 AM
jdmsiR20's Avatar
Default Re: (dubzz24)
^^ the thing here is... that there isn't a definite answer.
sure, you can drive on your basemap, and get on it. is it recommended? absolutely not....
basemaps are made to get your car to the tuner, to have it properly set up. in the end, its your money that you're risking, and im sure that you'd rather not have to throw in another block just because u wanted to get on it sooner.
tuning is key!
Old May 13, 2007 | 08:44 AM
adseguy's Avatar
Default Re: (jdmsiR20)
To add on top of what was said. Not only will everything in your system accumulate carbon build up but the excess fuel will also remove oil off the cylinder walls shortening the life span of your engine. This is all besides the fact that you are wasting gas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">
tuning is key!</TD></TR></TABLE>
h2b_sedan
Engine Management and Tuning
Nov 29, 2009 05:45 PM
bigtom388
Nov 21, 2009 12:30 PM
racin jasin R
Jun 24, 2007 11:08 PM
crx88fast
Mar 5, 2005 01:15 PM
espanol
Mar 13, 2003 09:23 AM
