Finding the safe rev limmit
Old Feb 14, 2006 | 03:38 AM
GarageAlchemist
Guest
Posts: n/a
Default Finding the safe rev limmit
So after i'm done i'll have a new engine, with a aftermarket valvetrain and such. Which brings the question, what should i do with my rev limmit.
sooo.. i'm gonna asume i'll make power above the 7, 400 or whatever the rev limmiter is on a p28.. what should i do to safely set it.. using chrome btw
99 ek
golden eagle sleeved d16z6
supertech valvetrain, oversized valves, a very ported head.
Stock cam
acl race bearings,
polished/deburred crank
eagle rods
wesco pistons 8.5:1
balanced/blueprinted
stock ignition,
a whole bunch of that boost stuff... btw
do i get the basemap, do a base run, and find out where i make power to, and then step it down a little to be safe, ? as long as the a/f ratio can be balanced ?
Old Feb 14, 2006 | 04:20 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Finding the safe rev limmit (GarageAlchemist)
id say just turn it to where the power drops off then back it off a couple hundred rpm
Old Feb 14, 2006 | 04:28 AM
The Weather Man's Avatar
if you hvae an aftermarket valvetrain, most likely, it will be able to handle whatever you throw at it. So like he said, whenever you stop making power - cut it off.
He recommends backing off a few hundred, I actually recommend adding a few hundred - just so your shift point can be better.
Old Feb 14, 2006 | 05:01 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (TheKINGPin)
a few hundred after drop off.. scaryyy
on a side question, i just didn't wanna spam a bunch of posts.. i was gonna shave a couple grams off the valve rockers.. anyone do this, and think i would need to worry about stress ?
Old Feb 14, 2006 | 05:04 AM
Default Re: (GarageAlchemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">a few hundred after drop off.. scaryyy
on a side question, i just didn't wanna spam a bunch of posts.. i was gonna shave a couple grams off the valve rockers.. anyone do this, and think i would need to worry about stress ?</TD></TR></TABLE>
Scary? How so?.......i'm talking 200-300.......there's nothing wrong with that. I'm doing that right now a matter of fact - because I have an 8lb flywheel, and the rpms drop faster. So that extra 200-300 shift point helps a lot.
Old Feb 14, 2006 | 05:12 AM
GarageAlchemist
Guest
Posts: n/a
i mean just on the dyno taking the valvetrain to the limmit... supertech valves, supertech rets/stpingsported head, flowbench very well, skunk2 intake, 70mm tb,
hmm, new gaskets, valveguides, stock cam.. maybe i should do a cam.. i just don't know if a cam out there has the same core metal composition.. shrug, i like oem for cams
Old Feb 14, 2006 | 05:21 AM
nah - i think your valvetrain should definately be able to handle atleast 8500; however, your bottom end might not be able to handle it. Whatever power you're making, it should be fine valvetrain wise.
Old Feb 14, 2006 | 05:25 AM
GarageAlchemist
Guest
Posts: n/a
can't go wrong with eagles and wesco's, balanced, stock crank... but should do 500whp
Old Feb 14, 2006 | 06:22 AM
Everyones Hero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist &raquo;</TD></TR><TR><TD CLASS="quote">can't go wrong with eagles and wesco's, balanced, stock crank... but should do 500whp</TD></TR></TABLE>
I think he's talking more along the lines of spinning a rod bearing or not getting enough oil to the lower end.
Old Feb 14, 2006 | 06:46 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (Everyones Hero)
ahh oil oil oil
Old Feb 14, 2006 | 06:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero &raquo;</TD></TR><TR><TD CLASS="quote">
I think he's talking more along the lines of spinning a rod bearing or not getting enough oil to the lower end.</TD></TR></TABLE>
yep
Old Feb 14, 2006 | 12:16 PM
wantboost's Avatar
Who is Mr Robot?
and the d-series pumps suck ***. hmm, you would try porting out the oil outlet and inlet, etc. if not you may want to look into a dry sump setup if oiling concerns you that much
Old Feb 14, 2006 | 12:18 PM
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">and the d-series pumps suck ***. hmm, you would try porting out the oil outlet and inlet, etc. if not you may want to look into a dry sump setup if oiling concerns you that much</TD></TR></TABLE>
I'm going to have to look into that.
I think it was Earl that had a thread about porting out something oil related on a d-series. I could have sworn it looked like bearings, but rob bearings don't have holes in them.
175Shot4Door
Aug 22, 2006 07:44 PM
thedirty-Dseries
Apr 18, 2006 07:16 PM
doood
10
Jul 3, 2005 06:21 PM
comptechgsr
Apr 24, 2002 06:03 PM
Spade
Nov 28, 2001 01:26 PM
