Finally got Tuned.
Old Jul 13, 2004 | 12:03 PM
SC61HB's Avatar
Default Finally got Tuned.
I have a 1996 Civic HB with a JDM ITR swap. About a week ago I installed a Drag 3 kit. I of course upgraded to RC 550cc injectors, Tial 38mm wastegate, Walbro 255, and Hondata S200B.
I just got her tuned Sunday. In the 101 degree dyno shop, I put down 250hp and 183 torque @ 6.5psi. I was alittle disappointed because I wanted some higher numbers. I even had a .5Bar spring in the wastegate, but I guess it lost alittle across the intercooler.
I really don't know what I can expect to run in the quarter. Maybe a low 13. It's hot and humid as hell where I'm at, so any runs would probably be disappointing.
Old Jul 13, 2004 | 12:24 PM
Drag_On's Avatar
Default Re: Finally got Tuned. (zgrieger)
Numbers sound about right for low PSi. You could bring it up a little - but ITR motors only do like 165 stock - so adding 95 some horse from only 6 psi isnt bad. If you pushed up to 8psi - I'm sure you could near 300 on a good tune.
Old Jul 13, 2004 | 12:52 PM
RobbieG35's Avatar
12 Years Strong
Default Re: Finally got Tuned. (Drag_On)
Looks like great numbers for such low boost, I would be happy
Old Jul 22, 2004 | 08:30 AM
93H22ACX's Avatar
Default Re: Finally got Tuned. (HybridHatch88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zgrieger &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1996 Civic HB with a JDM ITR swap. About a week ago I installed a Drag 3 kit. I of course upgraded to RC 550cc injectors, Tial 38mm wastegate, Walbro 255, and Hondata S200B.
I really don't know what I can expect to run in the quarter. Maybe a low 13. It's hot and humid as hell where I'm at, so any runs would probably be disappointing.</TD></TR></TABLE>
those numbers freaking sucks!!!!!!!!!
just kidding...damn good numbers for such low boost man! be happy
Old Jul 22, 2004 | 08:34 AM
racinskittle's Avatar
I just got her tuned Sunday. In the 101 degree dyno shop, I put down 250hp and 183 torque @ 6.5psi. I was alittle disappointed because I wanted some higher numbers.</TD></TR></TABLE>
Well boo hoo, there's guys putting down WAY less than that on the same psi. You're lucky you did so well. You have nothing to worry about.
Old Jul 22, 2004 | 10:29 AM
SC61HB's Avatar
Well, my motor is out of commission. It must have leaned out, thus causing my number 4 piston to start melting. No worries, I'm gonna fully build the bottom end and come back stronger. Here's the link to my post about my engine --&gt;https://honda-tech.com/zero...27545
90TegraB18C
Apr 17, 2006 02:40 PM
jamartin0519
Sep 20, 2004 05:41 AM
95GSRTT
May 23, 2004 10:49 AM
homesauce
Mar 12, 2004 01:56 PM
accordfreak
Aug 3, 2003 02:15 PM
