finally got my crank bolt off!!!
Old Jun 20, 2002 | 05:47 PM
markaria's Avatar
Default finally got my crank bolt off!!!
I ended up getting the moroso tool from summit and between having my father in law hold that while I hammered on my breaker bar, It finally broke loose. All I can say is thank god! One step closer to the darkside...
Old Jun 20, 2002 | 05:53 PM
CovertFI's Avatar
Default Re: finally got my crank bolt off!!! (markaria)
i was thinking about buying that tool because i cant take mine off. how long is the handel?
Old Jun 20, 2002 | 06:01 PM
markaria's Avatar
Default Re: finally got my crank bolt off!!! (CovertFI)
the handle is about 22" long
Old Jun 20, 2002 | 07:00 PM
GruvyTune's Avatar
New User
do the flywheel locking technique, takes about 15 minutes of time and you will get the bolt off and back on in no time. I got that tool but the flywheel technique is where its at! do a search for crankshaft bolt and you will find it.
Old Jun 20, 2002 | 09:36 PM
paulzy's Avatar
Default Re: finally got my crank bolt off!!! (GruvyTune)
I use the tool sometimes, but man, I love impacts
Old Jun 20, 2002 | 10:34 PM
dustin's Avatar
this is what I do. works
Old Jun 20, 2002 | 11:01 PM
wicx's Avatar
c'mon guys invest in an air compressor and an impact.
save you alot of stressing,pulling muscles etc..but brute force is always good if an air compresor is not affordable
just my 2 cents
Old Jun 20, 2002 | 11:03 PM
dustin's Avatar
Default Re: finally got my crank bolt off!!! (NightKids)
I have an air compressor and an 500ft-lb impact gun.
Some crank pulleys it takes off in one hit.
Others it won't even budge.... so we use the flywheel trick
Old Jun 21, 2002 | 02:16 AM
downpipe's Avatar
Default Re: finally got my crank bolt off!!! (dustin)
the search din't turn anything up. i am wondering if your flywheel technique is the same as mine. i just took an old bolt and screwed it through until it caught itself on the block....
beansandrice
Jun 27, 2011 02:01 PM
Powered By Garrett
Nov 4, 2010 10:00 AM
fastdohc
Jul 27, 2010 07:14 PM
clayne
Oct 19, 2006 10:25 PM
