final turbo install prep
ok, a couple quick questions. im installing my max rev kit on sat, and need to get the xtra stuff ill need now. neways, first off, do i use teflon tape or liquid loctite stuff? and am i supposed to use the tape or lock tite on the an fittings? also, do i use silicon sealant on the oil return flange on the turbo? and do i need gaskets for the turbo to manifold and dp to turbo? thanks.
teflon tape for the fittings is a
loctite for downpipe bolts is a
usually the oil return flange comes with a gasket.
you dont need gasket for dp to turbo
what about a gasket for turbo to manifold? and do u mean the return flange on the turbo? cuz thats what im talking about. its the 1 that comes w/ the max rev kit. thanks.
im gonna install my dsm injectors now to save some time, what do i set the safc to until i install the turbo? and do i just open up the gas cap to relieve the pressure so i dont get gas squirting all over? thanks.
bruthaboost
Jun 5, 2002 10:17 AM
