Final Shots of my setup!!
Old Apr 21, 2003 | 09:53 PM
  #26
SiRkid's Avatar
Default Re: Final Shots of my setup!! (BseriesPWR)
very awesome.
im losing hope for my set up yet im so close..
argh.
nice to see a good set up finished.
Old Apr 21, 2003 | 10:53 PM
  #27
censored's Avatar
Default Re: Final Shots of my setup!! (SiRkid)
just curious when do you start spooling/hit full boost with that turbo, also what numbers are you looking to put down? (sorry if I missed it)
Old Apr 21, 2003 | 10:58 PM
  #28
Midwestrider's Avatar
Default Re: Final Shots of my setup!! (CzanSOHC)
Car looks good man..
Old Apr 21, 2003 | 11:10 PM
  #29
CzanSOHC's Avatar
Default Re: Final Shots of my setup!! (H-T Member)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-T Member &raquo;</TD></TR><TR><TD CLASS="quote">just curious when do you start spooling/hit full boost with that turbo, also what numbers are you looking to put down? (sorry if I missed it)</TD></TR></TABLE>
the spool is fast...but i run a Full 3" exhaust, EBC and a lighter flywheel to help it. I get fulll boost from a stop at about 4000k ish.
Old Apr 21, 2003 | 11:15 PM
  #30
CzanSOHC's Avatar
Default Re: Final Shots of my setup!! (Midwestrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midwestrider &raquo;</TD></TR><TR><TD CLASS="quote">Car looks good man..
thanks erik...your green beast will be done soon enough
Old Apr 22, 2003 | 12:20 AM
  #31
accordfreak's Avatar
hey what kind of oil feed fittings did you get? was it expensive? got a parts list?? what brand fittings? .. it's lookin good!
Old Apr 22, 2003 | 12:21 AM
  #32
Broken Gearbox's Avatar
Default Re: Final Shots of my setup!! (accordfreak)
very clean car...that lip looks cool
SOHC power
Old Apr 22, 2003 | 06:02 AM
  #33
boostin b16's Avatar
Default Re: Final Shots of my setup!! (s_o_h_c)
for your down pipe bolts ...did you use allen head bolts because you could not get a hex head bolt on there? and if you didi use allen head blots where did you get them?
Old Apr 22, 2003 | 06:17 AM
  #34
CzanSOHC's Avatar
Default Re: Final Shots of my setup!! (boostin b16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostin b16 &raquo;</TD></TR><TR><TD CLASS="quote">for your down pipe bolts ...did you use allen head bolts because you could not get a hex head bolt on there? and if you didi use allen head blots where did you get them?</TD></TR></TABLE>
Yea, those are allen head bolts. I got them for 2 reasons, first, you cannot mig weld the 3" pipe to the flange becuase you won';t have rom for the bolts, you have to either tig around the bolt holes and mig the rest(what i did) or tig all of it but that can make it weak. They are stainless allen head bolts, i got them at a local hardware store.
Old Apr 22, 2003 | 06:43 AM
  #35
Honda4CX-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CzanSOHC &raquo;</TD></TR><TR><TD CLASS="quote">
Quote, originally posted by totaled »
how much did everything run you in the end? $$?
WAY TO MUCH!!!!</TD></TR></TABLE>
Agreed ..... so true !
Old Apr 22, 2003 | 07:33 AM
  #36
M.A.R.C.'s Avatar
Right now I'm running the AFC hack and i hate it. Throwing a MAP code and my idle is ******* crazy somtimes...going w/ hondata s200 in june so i'll get some #'s!</TD></TR></TABLE>
really? you sure the wiring is OK? what settings are you running and what size injectors again?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbod16y8 &raquo;</TD></TR><TR><TD CLASS="quote">
damn another boosted black civic...</TD></TR></TABLE>
yah tell me bout it...
not to steal the post but kinda looks similar
we're taking over damnit... Black Turbo SOHC's OWN ALL!!!
Old Apr 22, 2003 | 11:20 AM
  #37
gitwidit's Avatar
Beautiful SOHC! Makes me wanna go turbo, Why are you waiting till June to get it tuned at Tom's?
Old Apr 22, 2003 | 12:35 PM
  #38
CzanSOHC's Avatar
Default Re: Final Shots of my setup!! (GITWIDIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GITWIDIT &raquo;</TD></TR><TR><TD CLASS="quote">Beautiful SOHC! Makes me wanna go turbo, Why are you waiting till June to get it tuned at Tom's?</TD></TR></TABLE>
Old Apr 22, 2003 | 01:28 PM
  #39
Old Apr 22, 2003 | 05:54 PM
  #40
CzanSOHC's Avatar
From the block i run a 1/8 bpst to a 4an line to the fire wall. From the firewall "t", 1 4an line goes to my mech oil pressure gauge and the other is a 3an line to my turbo. I runs about $70 or so. I can get you a parts list if you like.
Old Apr 22, 2003 | 06:00 PM
  #41
HondaCutter's Avatar
i noticed that your DP is right on your radiator, are you running a pusher fan setup?
Old Apr 22, 2003 | 06:11 PM
  #42
CzanSOHC's Avatar
Default Re: Final Shots of my setup!! (HondaCutter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCutter &raquo;</TD></TR><TR><TD CLASS="quote">i noticed that your DP is right on your radiator, are you running a pusher fan setup? </TD></TR></TABLE>
yes sir..hers a thread i made a while back https://honda-tech.com/zerothread?id=370866
Old Apr 22, 2003 | 06:26 PM
  #43
Trac226's Avatar
Awesome man, I know you've been working on this setup for quite some time now. Enjoy your boost and beef up your security!
97civic_coupe
Dec 14, 2008 09:05 PM
JDM_EM1
Honda S2000
46
Apr 22, 2008 08:27 AM
civicnar
Apr 16, 2006 11:42 PM
tonezilla
Jan 17, 2004 09:33 PM
vtec.dc2
Dec 13, 2002 02:48 PM
