filter over HKS SSQ
Old Feb 8, 2004 | 02:18 PM
JrCRXHF's Avatar
Default filter over HKS SSQ
when i was tech inspecting SSCA pro rally there was alot of high end "open" car that had a filter over there HKS BOV. i was told this is to keep dirt out has anyone on the road had a problem with not putting a filter over there BOV i do not have one oh my HKS but it is also mounted up high.
Any thoughts would be good.
Old Feb 8, 2004 | 04:18 PM
pornstarSR's Avatar
Default Re: filter over HKS SSQ (JrCRXHF)
where would the filter go....
someone have a pic of it... i would like to see
Old Feb 8, 2004 | 06:57 PM
JrCRXHF's Avatar
Default Re: filter over HKS SSQ (pornstarSR)
some say that some air gets in the bov under vac conditions so really don't know if i should be worried or not. i have the HSK SSQ so i don't know if i should be worried or not.
Old Feb 9, 2004 | 01:42 PM
JrCRXHF's Avatar
bump
Old Feb 10, 2004 | 08:46 AM
opto_isolator's Avatar
According to HKS, the SSQV is supposed to remain closed at vaccum - so apparently a filter is not required.
Old Feb 10, 2004 | 08:49 AM
vtec.dc2's Avatar
you should be fine without the filter
Old Feb 10, 2004 | 10:45 AM
Mr. Softee's Avatar
Default Re: filter over HKS SSQ (vtec.dc2)
it remains closed at vac if you use the check valve
Old Feb 11, 2004 | 11:01 AM
t3t460-1's Avatar
Default Re: filter over HKS SSQ (94goldjungsr)
the only reason they use it on rally cars is because of all of the dirt and mud and water, you dont get that driving daily you know.
Old Feb 15, 2004 | 01:09 PM
pornstarSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JrCRXHF &raquo;</TD></TR><TR><TD CLASS="quote">
some say that some air gets in the bov under vac conditions so really don't know if i should be worried or not. i have the HSK SSQ so i don't know if i should be worried or not.</TD></TR></TABLE>
i wanted a picture or the SSQ with a filter
Old Mar 9, 2004 | 12:51 PM
JrCRXHF's Avatar
which way does the black check valve go for the hks there is a little rasied part. which way does that go towards the HKS or away..
Old Mar 9, 2004 | 03:49 PM
JrCRXHF's Avatar
bump for the check valve
Old Mar 9, 2004 | 04:13 PM
Street_Kings's Avatar
yeah the SSQV is designed so it stays shut at VAC., so it's not really needed. What you could do if you are worried about it is get the recirculation kit, and run it back to the intake pipe between the air filter and compressor wheel.
xfrankx
May 27, 2005 07:47 PM
Snail EK
Jan 12, 2005 09:41 PM
igotyofire
Dec 30, 2003 09:54 PM
Kutsuju_SLeePER
Oct 15, 2003 03:40 AM
utensil
Dec 26, 2001 01:39 AM
